rmenke
Joined: 6/25/2004 From: Merced, Ca., CA, USA Status: offline
RT: Yes, had one, Jett 50 powered. About the same speed as a Q-500 with similar engnes. Mine died from a switch failure, hit so hard battery went through the tank, and firewall and damaged the rear of the engine fins. Unless you are going to race this thing, no catagory for it, suggest you get the 15% wing. Makes the plane more user friendly, cost you 10-12 mph which you will never notice and make slowing down and landing easier. Do not get the 12% wing if you do not fly Quickees or formulas. Once the engine quits, you need to make almost a complete circle of the field to slow the thing down, and still lands a little hot. Kevin will tell you the same thing. It will do almost a complete B pattern if you have a throttle, and will hover for a while, decent flyer. Its a lot of work for something you cant race with, but a funn flyer regardless. ENJOY
