Additional wheel collers on the flybar
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Additional wheel collers on the flybar
Page: [1]
Login
Additional wheel collers on the flybar - 9/24/2007 10:42:38 PM
MMatheny
Status: offline
Should the be out by the paddles, or in next to the carrier?
_____________________________
Mike
"Never use your shins as a blade tracking device" - Mike
       Post #: 1
RE: Additional wheel collers on the flybar - 9/24/2007 10:44:48 PM
thestratcat
Status: offline
out dude-man... move them out to the paddles...
"If guns cause crime, all of mine are defective" ~ Ted Nugent.
(in reply to MMatheny)
       Post #: 2
RE: Additional wheel collers on the flybar - 9/25/2007 12:57:07 AM
USHobbySupply
Status: offline
out for docile, slower cyclic response
closer for faster cyclic response.
Michael Bernstein, President, USHobbySupply
Please PM me if I miss you question in a thread
(in reply to thestratcat)
       Post #: 3
RE: Additional wheel collers on the flybar - 9/25/2007 3:37:52 PM
123Splat
Status: offline
I fly with one all the way in and the other one about halfway out to do the 'funky chicken' while airborne. also helps to cant both the paddles about 6-8 degrees... in the same direction.
Sorry guys, just couldn't resist......
Seriously, agree with all the above. All the way out, otherwise, there's no reason to put 'em on the bird.
Splat
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
(in reply to USHobbySupply)
       Post #: 4
RE: Additional wheel collers on the flybar - 9/25/2007 7:07:27 PM
MMatheny
Status: offline
So, I could move them out until I don't need them, then move them in?
Mike
(in reply to 123Splat)
       Post #: 5
RE: Additional wheel collers on the flybar - 9/25/2007 7:13:24 PM
thestratcat
Status: offline
quote:
ORIGINAL: MMatheny
use them until you don't need them and then why not move them off? the stability you are looking to gain is to your advantage as a beginner, when you are comfortable, you won't want to keep them on, remove them and get the full performance instead...
make sense?
       Post #: 6
RE: Additional wheel collers on the flybar - 9/25/2007 7:36:45 PM
MMatheny
Status: offline
Awh, I just hate unscrewing the paddles to remove them!! Also, how do you break a paddle? I have put some dings in the rear of my blades with the paddles, but they are as good as new!
Also, I thought I read that the E-Flight paddles are better - in what way?
Mike
       Post #: 7
RE: Additional wheel collers on the flybar - 9/25/2007 7:51:41 PM
123Splat
Status: offline
Strat's the man!
Better is relative, I think they have a little more mass and surface area. which means they are likely to give you more sensitive response (NOT what you are looking for at this point).
If you are that opposed to removing the paddles again, when you are comfortable with your control, move the weights all the way in on the flybar, then when you think you are really ready to do without, grind or cut them off with a Dremmel tool.
Splat
       Post #: 8
RE: Additional wheel collers on the flybar - 9/25/2007 10:52:22 PM
nothinbetr2do
Status: offline
quote:
ORIGINAL: MMatheny
they should be out by the paddles
just say no to "shelf queens"
       Post #: 9
RE: Additional wheel collers on the flybar - 9/25/2007 11:11:05 PM
thestratcat
Status: offline
quote:
ORIGINAL: MMatheny
hmmmm, I was thinking...
I thought the deal on the e-flight paddles was they were lighter? hmmmm, if they are, when everyone puts their wheel collars on adn changes to the e-flight paddles, we're kind of nullifying everything right? (just thinking out loud there)
the MX400 paddles have a set screw on them, let me check out the flybar on my CP and the paddles and see if they'll work together, I think they are a bit heavier (more stability right?) besides that easier to take on and off or move to get the balance right...
       Post #: 10
RE: Additional wheel collers on the flybar - 9/26/2007 3:06:55 PM
123Splat
Status: offline
Strat,
My bobble. I thought that they were bigger (more airfoil area). I stand corrected.
Splat
       Post #: 11
RE: Additional wheel collers on the flybar - 9/26/2007 3:18:11 PM
thestratcat
Status: offline
quote:
ORIGINAL: 123Splat
Strat,
Splat
hey man, don't consider my senseless babblings as gospel...
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
