RE: What engine comes on a Troy bilt weedeater? Its a ryobi 31cc Lets convert it!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: What engine comes on a Troy bilt weedeater? Its a ryobi 31cc Lets convert it!
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/7/2007 6:33 PM
JIMARRINGTON
Score: 100
Last Login: 8/27/2011
Status: offline
I have a question. The engine has to be spun over pretty rapidly to produce the spark needed to start. I have been starting it by using my 3/8 electric drill. Would I be able to hand flip start the engine if I converted it to gas/glow? Don't want to go to EI. No funds at the moment.
Jim
Hide Signatures
(in reply to av8tor1977)
       Post #: 126
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/7/2007 9:43 PM
Ralphbf
Score: 100
Last Login: 7/6/2011
Status: offline
The honest answer here is, " You should be able to."
Especially once you get it tuned up and running right.
_____________________________
Ralph
Hide Signatures
(in reply to JIMARRINGTON)
       Post #: 127
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/7/2007 9:50 PM
JIMARRINGTON
Score: 100
Status: offline
Next question. The usual agreed upon mixture is 2 parts premium and 1 part glow fuel. I already have several gallons of 10/20 glow fuel. Will this fuel work in the above mentioned mixture? And do I still need to add some 2 stroke oil to the mix or does the oil in the glow fuel suffice?
Jim
Hide Signatures
(in reply to Ralphbf)
       Post #: 128
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/8/2007 12:34 AM
Ralphbf
Score: 100
Status: offline
Will it work? Yes.
Will it work well? It depends on you defination of well?
No you will not need to add oil, you already have twice to much.
I have used 10/18 and it ran and idled in a 32cc Mac.
But not near as good as well 10/10 does.
I've told people 10/18 is okay to try to see if there is hope but any more oil than 10%
and your taking away alcohol that is needed to make the glow plug work.
Actually 10% oil is a little to much, I believe 8% is what is required for a 2 stroke ball bearing engine.
Ralph
Hide Signatures
       Post #: 129
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/8/2007 2:47 AM
JIMARRINGTON
Score: 100
Status: offline
So, the glow fuel is just to keep the glow plug hot. Is there a readily availabe substitute for glow fuel on the market that we could add to gas that would keep the glow plug hot. If so, then we could just use normal 2 stroke oil like before. Asking because I really dont know for sure what is in glow fuel and what part of it is needed for the glow plug.
Jim
Hide Signatures
       Post #: 130
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/8/2007 3:01 AM
captinjohn
Score: 247
Last Login: 5/25/2013
Status: offline
You could buy alcohol from speed shop. Mix 1 gallon of alcohol with 2 gallons of gas. Also from speed shop you will need Nitro. You will need 15/100 or 15% of a gallon of Nitro. Then buy some Klotz oil and mix that in at 32/1 ratio. Should be close for some good running! Good Luck Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 131
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/8/2007 5:48 PM
JIMARRINGTON
Score: 100
Status: offline
Thanks Capt,
What kind of alcohol? When you say speed shop, do you mean an auto racing shop?
Jim
Hide Signatures
(in reply to captinjohn)
       Post #: 132
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/8/2007 9:37 PM
captinjohn
Score: 247
Status: offline
Yup..you may find alcohol at where ever they race. Go carts, snowmobiles, cars, Motorcycles, dune buggies, 4-wheel drives.....ect. Good luck Capt,n
Hide Signatures
       Post #: 133
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/8/2007 10:02 PM
JohnF
Score: 100
Last Login: 5/24/2013
Status: offline
Getting back to a prop. You might want to try a Master Airscrew 18x10 wood schimitar for your SE5. I have a Ryobi that I converted but with a CH ignition and it spins the 18x10 at around 7500. I am also using a Walbro wt644 big bore carb and Wacker muffler.
Hide Signatures
       Post #: 134
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/10/2007 9:15 PM
JIMARRINGTON
Score: 100
Status: offline
How long should the engine be run to break in the new ring? Considering that the cylinder, piston, and crank are well used. Not original cylinder and piston though. These were swapped from another engine. All used.
I ran a full 10 once tank of fuel through it today. It peaked out at 7200+ RPM on a MAS Classic 18x8. Should fly the SE well at that rpm I think. Do yall think it will get better still over time?
Jim
Hide Signatures
(in reply to JohnF)
       Post #: 135
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/11/2007 3:52 AM
captinjohn
Score: 247
Status: offline
I have re-used piston rings with pretty good success. Make sure the ring grooves in piston are carbon free. You can use a broken piston ring "ground to a square edge to do that. Take cylinder and break the "Glase" with sand-paper..or whatever. I also Polish the flat side of the piston rings on a real flat surface using fine high grade sand-paper. I use a circular motion. Works for me!! Capt,n
Hide Signatures
       Post #: 136
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/11/2007 4:51 AM
JIMARRINGTON
Score: 100
Status: offline
I meant to say that the piston ring is new. I put a new Bowman piston ring on it. The piston and head are used from two different engines. What I meant to ask is how much more break in is required for the new piston ring?
Jim
Hide Signatures
       Post #: 137
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/11/2007 6:34 AM
captinjohn
Score: 247
Status: offline
I talked with Mr. Boman himself. It only takes about 15 min for his rings to break (seat) in! Capt,n
< Message edited by captinjohn -- 11/11/2007 7:17 AM >
Hide Signatures
       Post #: 138
RE: What engine comes on a Troy bilt weedeater? Its a r... - 11/11/2007 5:33 PM
JIMARRINGTON
Score: 100
Status: offline
I guess that means this engine is ready to go. Now I just need an airplane to put it in. LOL
JIm
Hide Signatures
       Post #: 139
RE: What engine comes on a Troy bilt weedeater? Its a r... - 4/5/2008 8:27 AM
WILDGAS
Score: 100
Last Login: 8/30/2012
Status: offline
Where can i find the kit convertion for my Ryobi 31cc?
Thanks a lot, Carlos
Hide Signatures
       Post #: 140
RE: What engine comes on a Troy bilt weedeater? Its a r... - 4/5/2008 8:41 AM
Ralphbf
Score: 100
Status: offline
www.wackerengines.com
Ralph
Hide Signatures
(in reply to WILDGAS)
       Post #: 141
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: What engine comes on a Troy bilt weedeater? Its a ryobi 31cc Lets convert it!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
