2engsout
Hello, this is the only pic I have of it, sorry. I glued my wing panals together and it made it alot more stable flyer. If you can possibly haul it to the field as one piece, do it. With the dihedral envolved,,,I am not sure how secure the connection can be as a 2 piece wing. Also configure your spar posistions in the wing using the scale 6" dia. main tire. The plans only allow for a 4" dia. tire. Mine was already built when I bought it, so I had to cutout some material and then re-enforce it just to use 5" tires. I changed the roof line to the 1973 "Q" model, and added the rear and vista side windows. I really like the way it looks compared to the funky "G" model the plans are drawn from. Go to www.airliners.net and search "Cessna 310" and you will see 500 pics of the 310 from all angles. Its my main sorce of documentation. I skined the underside of the nacelle sheeting with 1/16" basswood epoxied in directly under the retract rails to secure a solid foundation for the 1/4" thick hardwood bridges that will support the bottom of the retract rails. As designed per plans,,,its a very weak area and I have seen several others break the rail mounting as I did before the re-enforcment. The wing servos are mounted in the wing directly ahead of the control horn with a short 4-40 pushrod with the servo shaft pointing towards the ground. Only the servo arm will be exposed. You will need acess to the servo so dont hide it. Use some 3/8" sq. hardwood stock to mount your aleron servos. You can use a wing spar and a wing rib to epoxy the stock to in conjunction with the wing sheeting. Use some aleron differential= more up throw than down throw. Down throw adds drag to the high wing, which you dont want when trying to bank. My plane banked soo much better after adding differential. My plane has exactly one half degree of positive wing incidence with the stab at "ZERO". Wing incidence was measured just outboard of the nacelles. Flys great ! Dont fly this plane without a twin sync ! Its got a ton and a half of drag on the dead engine side when you loose an engine!!= BAD..With a twin sync,,,the plane just slows down with the wings level= very nice. I personally would not want engines smaller than G-26's to fly this plane. Rick Simmons Zenoah engine beta tester for the twin sync.
