Richard L.
Joined: 7/28/2002 From: Redmond, WA, USA Status: offline
quote:
ORIGINAL: MicroDat Richard L., do you think if I carbon fiber rod the tail feathers, epoxy the backside of the firewall and baking soda+thin CA any balsa wood the ARF would be able to handle the 160 DZ? I'm not sure because I've never seen that combo before. Just merely putting extra epoxy to the backside of the firewall won't be enough because the firewall is only 3/16" thick. You will need to add a much thicker firewall and pin it to the fuse. The tail feathers will need two carbon fiber rods through each. The WM .60 Mustang has much stronger airfoiled tail feathers, so it might be a better choice for the 160DZ.
_____________________________
http://www.WarbirdObsession.com/ Tamiya Panther, Tamiya King Tiger(3), Tamiya Tiger I, HL Tiger(3), HL Panzer III(2), HL Panther, HL Pershing, HL Bulldog, WSN T-34/85, HE Leopard 2A5
