Long EZ 46 Modification - Retract Instalation
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> Long EZ 46 Modification - Retract Instalation
Page: [1] 2   next >   >>
Login
Long EZ 46 Modification - Retract Instalation - 9/26/2007 4:19:14 PM
shotgun06
Status: offline
I will post for those interested how I'm doing the instalation of a nose wheel retract on my Long EZ 46. I know that this airplane is not available anymore and probably will not be restocked but the retract could be retrofit to a flying airplane no problem. The retract is a Hobbico unit.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Alain
       Post #: 1
RE: Long EZ 46 Modification - Retract Instalation - 9/26/2007 6:55:26 PM
shotgun06
Status: offline
Should look a little more scale with the retract...Now I had to cut the bottom of the fuselage for the wheel well. I also added some 1/4'' harwood block on the platform to bring the retract flush with the bottom of the fuselage.
Click for fullsize
Click for fullsize
Click for fullsize
Alain
(in reply to shotgun06)
       Post #: 2
RE: Long EZ 46 Modification - Retract Instalation - 9/27/2007 3:19:26 AM
opjose
Status: offline
I'm interested!
Build em'', fly em'', crash em'' and build more.
       Post #: 3
RE: Long EZ 46 Modification - Retract Instalation - 9/27/2007 8:57:25 PM
shotgun06
Status: offline
I will continue to show my progress then
Alain
(in reply to opjose)
       Post #: 4
RE: Long EZ 46 Modification - Retract Instalation - 9/27/2007 9:01:25 PM
shotgun06
Status: offline
On the first picture you can see that I began to build the wheel well with 1/8'' balsa. In the second picture, I added a 1/8'' part of plywood to the top surface of the platform. It doesn't really mather how much weight I add around the nose wheel area since the black weight you see in the second picture is actualy meant to be on that platform for balance. If it become too nose heavy, all I will have to do is remove a chunk of that weight or change it for a lighter one. Since weight is not really a problem, I will add as much reinforcement that I feel is required to the front part of the airplane.
Click for fullsize
Click for fullsize
Alain
       Post #: 5
RE: Long EZ 46 Modification - Retract Instalation - 9/27/2007 9:22:59 PM
shotgun06
Status: offline
Now a little reinforcement to the front bulkhead since I made some cuts into it and not to mention that I'm adding a lot of epoxy everywhere in that area. As I was looking at the area of the main landing gear to see where it needed more glue, it became obvious to me that the next modification would be to add an air brake like the real thing...
Click for fullsize
Click for fullsize
Alain
       Post #: 6
RE: Long EZ 46 Modification - Retract Instalation - 9/28/2007 3:04:49 AM
TxDiveBomber
Status: offline
I'm following your progress as well... Looking good so far
       Post #: 7
RE: Long EZ 46 Modification - Retract Instalation - 10/3/2007 6:44:38 PM
shotgun06
Status: offline
Sorry if I'm slow to show my progress but I apparently have work to do to get my pay according to my boss...Anyway, I trial fitted the retract unit, put some epoxy on the blind nuts and completed the wheel well out of 1/8'' balsa and a block that I carved to accept the wheel.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by shotgun06 -- 10/3/2007 6:45:11 PM >
Alain
(in reply to TxDiveBomber)
       Post #: 8
RE: Long EZ 46 Modification - Retract Instalation - 10/3/2007 6:54:40 PM
shotgun06
Status: offline
I had to reverse the arm that control the elevator because there was not enough clearance left as the wheel well gets in the way. Not a big deal, I had to make some room in the bulkhead as you can see in the last picture.
Click for fullsize
Click for fullsize
Click for fullsize
Alain
       Post #: 9
RE: Long EZ 46 Modification - Retract Instalation - 10/3/2007 7:07:27 PM
shotgun06
Status: offline
I used a Dubro flex cable for steering control and a steel rod for retract activation. The steel rod is taking some room where the throttle servo is supposed to be located so I'm gonna have to use a smaller servo or move the servo somewhere else.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Alain
       Post #: 10
RE: Long EZ 46 Modification - Retract Instalation - 10/3/2007 7:25:09 PM
shotgun06
Status: offline
I built a servo tray to hold the retract servo and the SPEEDBRAKE servo. I found an old small servo that I bought many years ago for my 7 channel EK Logictrol radio (I still have it collecting dust...), it is still like new (don't remember the brand...) and I changed the plug to Futaba. It's working perfectly and it fits in the space left in the servo tray. Now I'm going to start working on the speedbrake...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by shotgun06 -- 10/3/2007 7:30:45 PM >
Alain
       Post #: 11
RE: Long EZ 46 Modification - Retract Instalation - 10/4/2007 9:25:50 PM
shotgun06
Status: offline
I carefully cut the shape of the speedbrake with the front being flush with the bulkhead and the rear being flush with 1/4'' stick I glued in front of the landing gear box. The sides are cut flush with the triangular stick on the bottom sides. That makes the speedbrakes almost exactly square. I made a plywood doubler for the brake and a control arm. I've glued in between 4 Dubro hinges side by side to make it look like it's a piano hinge like the real thing.
Click for fullsize
Click for fullsize
Click for fullsize
Alain
       Post #: 12
RE: Long EZ 46 Modification - Retract Instalation - 10/9/2007 5:22:19 PM
shotgun06
Status: offline
Last step for the speedbrake. I made a piece of plywood to fill the hole created by the speedbrake.
Click for fullsize
Click for fullsize
Click for fullsize
Alain
       Post #: 13
RE: Long EZ 46 Modification - Retract Instalation - 10/9/2007 5:31:58 PM
shotgun06
Status: offline
To finish retract instalation, I cut the nosecone to make room for the retract. I will have to wait to install the nosewheel since I broke the leg while I was trying to bend it. I ordered an adjustable axle to fix that. Anybody know how to bend piano wire without breaking it?
Click for fullsize
Click for fullsize
Click for fullsize
Alain
       Post #: 14
