MinnFlyer
MN, USA Status: offline
I can't say which is best. i use a mini-DV and it works fine, but I don't know anything about the other two, so I can't comment. But I CAN tell you this: Whichever you get, try out the camera before you buy it. What I mean by that is, hold it up to your face, push the buttons, try the zoom, etc. What I am seeing a lot of is that they are starting to make some of these cameras so small that it is a real pain for some people to operate them. (I prefer the slightly larger ones myself) Does the Eye Cup fit against your eye and block out other light, or do you just peer through a little hole? If you are going to be shooting outdoors a lot, you won't be able to see the image at all if the sun is blinding you. By the same token, if the camera doesn't even HAVE an eyepiece (Some only have the big screen) don't get it - you can't see that big screen in sunlight!
_____________________________
Mike B. AMA# 42400 www.gettingairborne.com "Those are my principles. If you don't like them, I have others." - Groucho Marx
