RE: 07 TopFlite Stinson build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: 07 TopFlite Stinson build Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: 07 TopFlite Stinson build - 11/29/2007 9:05:49 PM
Grotesquebass
Status: offline
hell yeah once you go gas you'll never go back i know corny but true i will never run glow again starting fuse front wish me luck guys
_____________________________
"I've got a fever and the only prescription is more cowbell"
(in reply to jaaron01)
       Post #: 226
RE: 07 TopFlite Stinson build - 11/29/2007 9:16:22 PM
jaaron01
Status: offline
I'm watching the little one while the wife makes a few trips. Once she gets home, it's game on. It'll probably take about 3 days to complete the front Fuse.
Day 1# set left and Right fuse side, and epoxy to former 3+4+ sides of frame.
Day 2# Epoxy front of Fuse together
Day 3# Epoxy in firewall, and extra bracing.
Should get step 1 done tonight....good luck to both of us.
Jim
(in reply to Grotesquebass)
       Post #: 227
RE: 07 TopFlite Stinson build - 11/29/2007 11:11:38 PM
Grotesquebass
Status: offline
quote:
ORIGINAL: jaaron01
Jim
i have 2 weeks till my wife comes back with little guy so i have to really get alot done lol time is running short haha
       Post #: 228
RE: 07 TopFlite Stinson build - 11/30/2007 3:07:17 AM
ramcfarland
Status: offline
Yes-'gassers'need to be "wet" to start or its:flip,flip,flip,flip... and the propeller MUST be balanced;no question-The first picture shows my balancing set up got it cheap from Doug's hobbies when they moved to Hollywood....
Well the right wing panel is going fast (for me at least) the photo sequence shows the steps taken per instructions to add the leading edge sheeting. Will be SO nice to frame the fuselage and then get lost in the finish details....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 229
RE: 07 TopFlite Stinson build - 11/30/2007 3:18:55 AM
jaaron01
Status: offline
I didn't get as far tonight as I wanted to. I only got the 1/4 x 3/8 sticks epoxied to the left&right fuse sides, along with the top plate glued and sticks epoxied to them. I didn't want to rush the front end set-up, as failure at that point would be disasterous, with a gas engine on the front. Tommorrow I'm heading down to lowes to buy about 6 each 3 in C-clamps. Then I'll be able to do some serious epoxing.
Hopefully by the end of the weekend I'll be mounting some landing gear so I can get this beast stable and on by work table. I'm still trying to decide on what to do with the landing gear. I really don't want to pony up the $50.00 for the 1 peice landing gear. I'll see as I'm working on that area if there might be a different alternative to that, so far I've not thought of anything.
Jim
(in reply to ramcfarland)
       Post #: 230
RE: 07 TopFlite Stinson build - 11/30/2007 4:08:14 AM
Grotesquebass
Status: offline
as i was reading in the manual is it updated to reinforce the gear i noticed the setup in the manual looks a bit differant that how it was on tims bird which was built a few years back any thoughts???ramcfarland....how does this build compare to the jug i am considering that for my next project
       Post #: 231
RE: 07 TopFlite Stinson build - 11/30/2007 3:49:56 PM
red1
Status: offline
Hi CrateCruncher -
I'm also inclined to use Titebond in preference to CA. Any helpful hints ?
Red 1 (aka Don Borton)
AMA IMAA
Waco Brotherhood #72
(in reply to CrateCruncher)
       Post #: 232
RE: 07 TopFlite Stinson build - 11/30/2007 7:47:45 PM
ramcfarland
Status: offline
quote:
ORIGINAL: Grotesquebass
Hello Jim,
Aside from sheeting the concave complex 'turtle deck,'if you chose the "Razor back version,"the Thunderbolt is a piece of cake-as a matter of fact I have enjoyed flying my 1/7 (I have both the 1/7&1/5) ...that I have another 1/7 63" wing span version and will frame it up over the winter and more than likely do it up as "Lucky" one of the late Capt. Robert S. Johnson's earlier mounts that he flew with the 56th FG
Well glue setting up and will be able to remove the right wing from the bench-Huuuraaaaaaaaaaaaaay
Red1 Titebond is great stuff needless to say just expect more pins and more clamps -
jaaron01: "C clamps" for sure-curious what you and others do regarding modifications if any to the landing gear. (keep us posted!)
Several Stinsons flown in my club and I plan on contacting one of the builder fliers to ask what if any modifications he did to the Reliants landing gear which supports a 'G-38.'
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 233
RE: 07 TopFlite Stinson build - 11/30/2007 8:08:59 PM
jaaron01
Status: offline
I would be curious as what they have to say about the landing gear. Most I've heard from have upgraded to the one-peice gear.
jim
       Post #: 234
RE: 07 TopFlite Stinson build - 11/30/2007 9:12:47 PM
ramcfarland
Status: offline
Hi Jim I plan on contacting him this weekend.
Richard
Fast Richard
       Post #: 235
RE: 07 TopFlite Stinson build - 11/30/2007 9:47:31 PM
CrateCruncher
Status: online
Red1,
The most important hint I can think of regarding Titebond is don't buy it in tiny 2oz bottles from hobby outlets for $4.50. It's a rip-off. I buy it by the pint (16oz) at home improvement stores for $7.95. Heck, a gallon (128oz!) is only $19.00 bucks. That should last a while even building planes with 100" wingspans.
Edit: Here's a recent thread:http://www.rcuniverse.com/forum/m_6132271/tm.htm
< Message edited by CrateCruncher -- 11/30/2007 9:54:14 PM >
(in reply to red1)
       Post #: 236
RE: 07 TopFlite Stinson build - 11/30/2007 11:17:22 PM
Grotesquebass
Status: offline
quote:
ORIGINAL: ramcfarland
Hello Jim,
thanks for the info dude debating between 1/7 and 1/5th
       Post #: 237
RE: 07 TopFlite Stinson build - 12/1/2007 3:06:44 AM
jaaron01
Status: offline
Grotesquebass: Thanks to cheap old walmart, my fuse is glued and drying. C-Clamps $1.97 each x 6. Here's a couple of photos not much to look at just C-clamps as far as the eye can see. Should be able to put the firewall in tommorrow morning, and before the weekend is out hopefully some landing gear braces.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 238
RE: 07 TopFlite Stinson build - 12/1/2007 3:41:15 AM
