RE: 07 TopFlite Stinson build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: 07 TopFlite Stinson build Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: 07 TopFlite Stinson build - 12/2/2007 4:10:06 PM
jaaron01
Status: offline
Well the landing gear rails are in place and epoxied. They are fun to install, as none of my landing gear pieces are drilled to match the template. So I went ahead and just lined up the two braces, and left out the center brace (made of balsa). Once this is all set up and hardened. I've got some 5 ply 1/4 plywood, left over from another project, that I'm going to make the center brace out of, then cut some 3/4 pieces and run along side the 1/4x3/8 basewood. Once all that is epoxied in place, I would think any kinda of landing that would break that, would destroy the plane anyway, reguardless of 1 piece gear or not.
The biggest problem is having the gear seperated (in two pieces) , and nothing in between them acting as a stiffener. A hard landing and they'll fold. I think my plan will take care of this problem. Here's some photos, but the extra bracing hasn't been added yet.
Jim
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to jaaron01)
       Post #: 251
RE: 07 TopFlite Stinson build - 12/2/2007 5:28:31 PM
Grotesquebass
Status: offline
can u send me a pic of where u put the basswood sticks on f3 that part was a little confusing
_____________________________
"I've got a fever and the only prescription is more cowbell"
       Post #: 252
RE: 07 TopFlite Stinson build - 12/2/2007 6:16:44 PM
jaaron01
Status: offline
Grotesquebass: Look in my pictures showing the landing gear first attached. They go on both sides of the 1/4 x 3/4 balsa brace on F3. Also if you look on a side view of the fuselage plans at the bottom of F3, right about the landing gear plates you'll see them sandwiched in there as well.
Update: Landing gear has been mounted minus the 1/4 balsa plate that goes between the landing gears plates. Instead I made up my own middle brace from 1/4 ply, along with two 1/4 x 3/4 ply rails. I placed them underneath the plate and used 4 blind nuts / 4 addtional 6/32 x 5/8 bolts, to suck everything together once epoxy was applied. So in addition to the Bottom former F3 1/4 x 3/4 balsa brace, which is sandwiched on either side by the 1/4 x 3/8 basswood sticks, then on top of those is this 1/4 ply landing gear rail brace (instead of the balsa intended to go there).
That will total 1/2 inch of ply wood running across the bottom of the landing gear. I'm pretty confident that if that breaks apart on a hard landing, there will probably be bigger items ( engine, fuel tank, wings, etc) laying around on the ground as well like confetti. With that said, I think it would be wise to build a removable cover over the landing gear, instead of sheeting it completely up and not having access to it. Just incase something goes wrong.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Grotesquebass)
       Post #: 253
RE: 07 TopFlite Stinson build - 12/2/2007 6:31:22 PM
Grotesquebass
Status: offline
thanks alot man i see it now duhhh lol i am going to do the same thing your doing with your lg and cancel the tnt ones(save me 60 bux) and instead of bolting it on i am going to epoxy sice that whole area gets sheeted
       Post #: 254
RE: 07 TopFlite Stinson build - 12/2/2007 7:30:49 PM
jaaron01
Status: offline
I used the 4 bolts to suck everything together, believe me there's epoxy in there as well.
       Post #: 255
RE: 07 TopFlite Stinson build - 12/2/2007 10:48:00 PM
Grotesquebass
Status: offline
haha cant be too safe huh lol............i am gonna mix plenty of milled fiberglass in there
       Post #: 256
RE: 07 TopFlite Stinson build - 12/2/2007 10:58:03 PM
jaaron01
Status: offline
Grotesquebass : I'll say one thing for your photo's, that's the cleanest, and most comfortable work shop I've ever seen! hah! hah! I'm stuck in a garage.
       Post #: 257
RE: 07 TopFlite Stinson build - 12/2/2007 11:26:41 PM
ramcfarland
Status: offline
Looking good guys un like the end of the Skins game
Fast Richard
       Post #: 258
RE: 07 TopFlite Stinson build - 12/3/2007 12:11:31 AM
jaaron01
Status: offline
I couldn't resist sitting the wings on there and seeing what she would look like. I've got the front Firewall area completed. Still filling some gaps from the earlier 1/8 gap incident, so that the inside of the cockpit will look nice and finished. Next step is to eat dinner, and place the triangle stock in the stab saddles, and fit/glue the horizontal stab.
I can just see this thing coming in for a landing and those big flaps just a hang'in and the landing lights down and shining. I'll have good dreams tonight.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ramcfarland)
       Post #: 259
RE: 07 TopFlite Stinson build - 12/3/2007 1:49:25 AM
Grotesquebass
Status: offline
lookin good brother, heres my progress fits nicely drilled holes and epoxy is drying
Click for fullsize
< Message edited by Grotesquebass -- 12/3/2007 2:16:05 AM >
       Post #: 260
RE: 07 TopFlite Stinson build - 12/3/2007 2:11:32 AM
jaaron01
Status: offline
Be sure and put the center piece in as well. They give you 1/4 in x 2 1/2 balsa piece, but I upgraded that to ply as well.
Anyway in the mean time, the Stab is glued on, and I'm done for the evening. I'll let her set till tommorrow and dry.
Jim
Click for fullsize
Click for fullsize
       Post #: 261
RE: 07 TopFlite Stinson build - 12/3/2007 2:18:15 AM
Grotesquebass
Status: offline
o i havent 4got ply here as well
       Post #: 262
RE: 07 TopFlite Stinson build - 12/3/2007 2:29:31 AM
Grotesquebass
Status: offline
quote:
ORIGINAL: jaaron01
now u see why i have 2 weeks to get as much done as i can the wife gets home lol spare bedroom hahah
       Post #: 263
RE: 07 TopFlite Stinson build - 12/3/2007 12:42:14 PM
ramcfarland
Status: offline
You guys got me up early and building---
*Now for those who have not started their build here is the bottom right wing panel with cap strips applied and ready for the flap and aileron build. Quite frankly I'm enjoying this build and look forward to the challenge of replicating a FACTORY style Stinson finish which the 'Reliants were noted for-'
Bringing it out to the field or perhaps even a club meeting will be a pleasure indeed.
Click for fullsize
Fast Richard
       Post #: 264
RE: 07 TopFlite Stinson build - 12/3/2007 2:18:02 PM
CrateCruncher
Status: offline
If the landing gear are not tied together no amount of mounting surface stiffening is going to prevent excessive movement and cracked fairings with such a small surface and so long a moment arm. Here is an inexpensive way to tie the two gear halves together. Bolt two of these made from aluminum to each gear half with two bolts on each leg. They don't have to be this fancy, any piece of scrap aluminum angle will do. Whats important is the flange. That creates the stiffness and prevents rotation of the gear legs. This is known in the truck industry as a "guppy belly tie plate" because it prevents the ladder frame from widening and twisting under excessive loads.
Mike
Click for fullsize
Click for fullsize
< Message edited by CrateCruncher -- 12/3/2007 2:24:50 PM >
       Post #: 265
