jimcork1
LA, USA Status: offline
Ok,, a new suggestion. I spent 1 hr trying to get the wing attaching bolts on at the field. What a . I would suggest that you use a threaded stud in the wing and use nuts inside the cabin if you decide to use this method to attach the wings. My preference if I were to do it again would be to hardwood dowel the wing jointer tube and then drill, tap for 1/4 x 20 nylon bolt then use dowels for alignment of the wing. This way the bolt would be outside of the cabin and make the wing attachment at the field more tolerable. You really won't like putting the bolts on inside the cabin. What looks cool for clean design is a poor user friendly setup. Just my $.02.
