RE: 07 TopFlite Stinson build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: 07 TopFlite Stinson build
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: 07 TopFlite Stinson build - 1/16/2008 2:53:40 AM
Grotesquebass
Status: offline
lookin good buddy the covering has commenced.........the white line is on straight just a bad angle
Click to see fullsize image.
Click for fullsize
< Message edited by Grotesquebass -- 1/16/2008 4:39:02 AM >
_____________________________
"I've got a fever and the only prescription is more cowbell"
(in reply to ramcfarland)
       Post #: 376
RE: 07 TopFlite Stinson build - 1/16/2008 5:40:03 AM
ramcfarland
Status: online
Yea thats a part I look forward to. Looks like its colored fabric you've applied to the rudder..so I'm thinking "Klass Kote clear?"
Anyway be brave-give some step by step on the application thing and it might just help me too
Fast Richard
(in reply to Grotesquebass)
       Post #: 377
RE: 07 TopFlite Stinson build - 1/16/2008 4:26:49 PM
Grotesquebass
Status: offline
its 21st century fabric so no paint is needed tonite i will be doing the elevators this is a learning expirience for me to i havent covered a plane since 98'
       Post #: 378
RE: 07 TopFlite Stinson build - 1/16/2008 11:21:48 PM
Grotesquebass
Status: offline
heres a few pics of some progress tonite i am taking a quick break for dinner then back 2 it in the meantime my little helper is giving the airplane his inspection before i continue if you'll notice i tried the glue method to simulate rib stitching and it looks great.....done with a monoject syringe and wood glue
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 379
RE: 07 TopFlite Stinson build - 1/17/2008 1:09:29 AM
ramcfarland
Status: online
The covering looks workable in application and authentic in looks. You are obviously a flier and surly will have your Stinson completed by sping time and with that said ,hope you can bring your Stinson to my clubs annual 'Spring Open House.'
Now remember I get the plastic I'm going to experiment a bit molding one way or another.
My Stinsons cowl is comming along good ; I added a forth light skim coat of Bondo and after finishing with sand paper blocks and (more flexible) rubber sanding pads available at your local auto body paint store- I like the detail of the cowl blisters, more on that later perhaps.I'm still waiting on a couple hobby items and I must say for living in such a populated and growing community that of Waldorf,MD its a total pain in the a-- to have to put up with ALL the shops,with all its associated traffic lights on the main throughfare and the near kaos and certainly conjestied neighboring streets.. and yet...not a single R/C type hobby shop
Click for fullsize
Fast Richard
       Post #: 380
RE: 07 TopFlite Stinson build - 1/17/2008 1:10:15 AM
Grotesquebass
Status: offline
alright i am done for the night.....i'm beat......the 21st century stuff is pretty good like i said i havent convered a plane for a while but i am amazed that even i can do it lol stinson shoulde be done in time for spring i also hope to have my bonanza done in time for summer. Ailerons and flaps are tomorrow i am not sure if i am going to do the struts or not but then again i did say the same thing about the doors and look what happened hehe
Click for fullsize
< Message edited by Grotesquebass -- 1/17/2008 2:42:09 AM >
       Post #: 381
RE: 07 TopFlite Stinson build - 1/17/2008 6:02:29 AM
ramcfarland
Status: online
Yes so many projects so little time.
I added the bottom formers in preparation for sheeting and finished the rocker covers and looked over the wheel pants and they seem nice. I must comment some plastic seems flimsey but there are a number of options so I will keep on...
Click for fullsize
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 382
RE: 07 TopFlite Stinson build - 1/18/2008 12:33:31 AM
Grotesquebass
Status: offline
heres tonites progress wifey took some pics....i think i am getting the hang of this.......
Click for fullsize
Click for fullsize
       Post #: 383
RE: 07 TopFlite Stinson build - 1/18/2008 3:06:37 PM
jaaron01
Status: offline
Okay,
So I've fallen a little behind. But there is so much detail work to accomplish, that it's hard to stick with just one thing. I'm still working on getting all my wiring placed in the correct spot. I did add a baggage door, and put the servo's back there. Also created a battery/receiver area under the belly to keep things out of the way.
The cockpit is wide open and I've been planning to get to that soon. Here's a couple of photo's of my progression or lack of.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 384
RE: 07 TopFlite Stinson build - 1/18/2008 6:48:39 PM
ramcfarland
Status: online
Great ideas the luggage compartment I was thinking about maybe I will go with that now as acess to to the airborn pack (s) and charge jack(s) and switch for lights depending on my Tx. program.-
No call from my LHS so I will make the call and get my Rudder pull pull and the covering ordered...
Fast Richard
(in reply to jaaron01)
       Post #: 385
RE: 07 TopFlite Stinson build - 1/19/2008 1:54:38 AM
jaaron01
Status: offline
I just couldn't bury those servos under the back seat and deal with all those wires. Plus with the G-38 I'm looking at needing to add weight to the rear, so why not move things back there. The one thing I had to do was extend the sheeting back to cover that section, so I would have something to work with. Once I did that I cut my opening, and added 1/4 balsa behind the door opening to help retain the curve of the fuselage.
It's a little tricky, but I'm hopeful it will be worth it. Got my door hinged and glued into place tonight, so we'll see in the a.m. what all will need to be tweaked for a good closure. I'm leaving a 1/32 gap all the way around to allow for covering material and expansion/contraction. Hope to start on my latch mechanism as well.
I included a shot of my wing tip light, but I'm thinking I'll call RAM and get the rounded light lens, as these square tipped ones just aren't doing it for me.
Also I've seen/heard about some problems with the Rudder counterbalance, and decided to go ahead and place some cloth with a little epoxy over that area, and stiffen it up some. I'm hopefull of later on in Feb to start getting some of the major pieces engine, Futaba 9 CAP, etc....but right now I've got so much detail work, that I can't really think about it.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 386
RE: 07 TopFlite Stinson build - 1/19/2008 4:24:13 PM
padoni
Status: offline
Ramcfarland: Thank you for keeping me in the loop of the Stinsen build. It has been a great help to me. I wish I was had the talent to be able to build like you and all the other folks. Waiting for more pics and explenations.
Halfstep
