RE: 07 TopFlite Stinson build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: 07 TopFlite Stinson build Page: <<   < prev  15 16 [17] 18 19 20 21 22 23 24   next >   >>
Login
RE: 07 TopFlite Stinson build - 1/30/2008 2:03:43 PM
roaddog2
Status: offline
RAM,
A question, if y' don't mind... Why wouldn't jus' plain water serve th' same purpose? I can't stand amonia!
Tnx,
RD
Montross, Va.
(in reply to ramcfarland)
       Post #: 401
RE: 07 TopFlite Stinson build - 1/30/2008 3:06:26 PM
bigphil
Status: offline
The amonia is supposed to make it penetrate the wood better. I'm with you though dog, it stinks so bad that I've always used just water. If the amonia really makes a difference, I wouldn't really know myself.
_____________________________
Big Phil
AMA 6762
(in reply to roaddog2)
       Post #: 402
RE: 07 TopFlite Stinson build - 1/30/2008 5:09:57 PM
Trinut
Status: offline
I use some isopropyl rubbing alcohol in the water, instead of amonia.
I just finished sheeting the fuse and making the doors. I used balsa in the door jams instead of ABS like the plan shows.
I soak the wood and wrap in around something of the same radius (as the corner of the door). When it dries it holds its shape.
Also, I used 1/8 inch radio shack rare earth magnets to hold the doors shut instead of making a latch. They hold the doors firmly shut against the fuse.
(in reply to bigphil)
       Post #: 403
RE: 07 TopFlite Stinson build - 1/30/2008 5:48:57 PM
ramcfarland
Status: online
Funny how this is going guys I seem to tolerate ammonia and like its benefits aiding in making the balsa considerably,more ply able for lack of another word. and a tendency to be mold able 'more' easily in this way.
Okay!! it stinks
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Fast Richard
(in reply to Trinut)
       Post #: 404
RE: 07 TopFlite Stinson build - 1/30/2008 6:15:01 PM
roaddog2
Status: offline
Roger your last! Think I'll try th' alcohol trick, tho'.
RD
       Post #: 405
RE: 07 TopFlite Stinson build - 1/30/2008 8:00:48 PM
ramcfarland
Status: online
added the number 2 section per page 39 step 7 (the pictures hopefully give an idea
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ramcfarland -- 1/31/2008 11:53:15 PM >
Fast Richard
       Post #: 406
RE: 07 TopFlite Stinson build - 1/31/2008 4:53:51 AM
ramcfarland
Status: online
I added the rear portions and for 'ole times sake' I tried windex maybe I pushed it but the balsa cracked- So I went ahead to my current method which is understandably a bit un pleasant a scent none the less it bothers me little and works WONDERS when bending balsa
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 407
RE: 07 TopFlite Stinson build - 1/31/2008 8:06:30 PM
ramcfarland
Status: online
Well as stated in the last installment I used ,rather re-discovered Windex and like the blond ape inside the cave at what turns out to be the N.Y. shore there is a talking doll which he the ape...chose not to aknowledge and so it is I will stick with ammonia ...sure the smell drives others "ape" but it works BEST.
Interestingly no wetting required at all for the bottom sheeting just a sequence that will save you time and -
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 408
RE: 07 TopFlite Stinson build - 2/1/2008 12:00:36 AM
ramcfarland
Status: online
Here is a shot of the fuselage nearing completion of sheeting and thinking about an 'access cover' for the mains as mentioned earlier by another great builder doing a Stinson.
Further I have included a photo of Windex send me 19.99 "+" shipping and handling and the jug is yours
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 409
RE: 07 TopFlite Stinson build - 2/1/2008 4:29:19 AM
ramcfarland
Status: online
Started the transition on the lower Longerons by adding SOFT 1/8" balsa. I'm looking at options with the cowl install and nearing still debating going for the early Gull Wing SR-7 as I've mentioned before,with its "40 Ford" type plate glass very distinctive but beauty is in the eye of the...
Click for fullsize
Fast Richard
       Post #: 410
RE: 07 TopFlite Stinson build - 2/1/2008 1:46:58 PM
TomCrump
Status: offline
I like the 40 Ford look. My IKON SR8 has the same windscreen.
Click for fullsize
Tom C
       Post #: 411
RE: 07 TopFlite Stinson build - 2/1/2008 3:02:44 PM
ramcfarland
Status: online
Thats nice there Tom . May I ask what it is covered and finished with and do you suggest any drawings etc. that would give me a good idea of the scale out line for the SR-7 and 8 Reliant Ford looking (for lack of another word) winshield??
Fast Richard
(in reply to TomCrump)
