LA, USA Status: online
Ok,, update. First day flights successful.
Ailerons very soft at reco settings. Can't aileron roll due to too slow. Flaps work well but have very slight pitch up. 2 clicks of down trim neutralized it,, Mix next flights Ail to rud mix 3/8 " total deflection is about right. This Mix really helps flying with flaps down in turns. Saito 1.8 a good power fit. Flies well but not overpowered. Plane heavy,, didn't weigh it. Landings are POC,, one wheel touch downs are possible but tip over to nose is easy. My wheels did not rotate easily and the wheel pants only allow 3/4" clearance and on grass this is like landing with brakes. Guaranteed tip over. Wing strut blind nut is now loose inside wing. DuH? Epoxy them in place or put small ply over the blind nut so it can't come loose. Flew with left strut load bearing attached and right for show. Did no loops , rolls , spins or any other stress. 16oz tank not big enough. 8 minutes air time landed empty. No reserve. Use 20+ oz tank for saito. Prop 16x8 classic MAS looks good but not very efficient. waste fuel Wing attach bolts use 1 1/2" so your hand will fit. 1" will not be long enough and make sure the blind nut is locked and a good one easy to cross thread.
Landing gear did not break off even with wheels not turning freely. But will have wheels fixed on next flight. I do have a movie of first take off.
Ya'll have fun the bird does fly and very scale with all the wow scale appeal. Jim
For those who would like to see the movie,, It is quick time and not supported on the forum. PM your email and I will email it to you. You must have HS inet and quicktime. If you don't have qt it is a free download,, just do a search. Jim
Epoxy them in place or put small ply over the blind nut so it can't come loose.[/quoteHummmmm anticipated that and will do so-Congrats on your maiden flight of your beautiful Reliant about to send you a PM"of course I want to see the flight video. One of our club officers has been flying a beauty of a Stinson and I keep missing the flights;more time at the field and less at the bench would solve that I think
Hi jaaron01 For an engine would like a 4/C perhaps the new O.S.200 (fuel consumption is an issue though ) I noticed an ad in the latest issue of M.A.N. magazine advertising a NEW Satio 220 I think it was and its a gas burner it sips fuel so states the manufacturer and thats believable. Well dependent on weather will get along on the wing construction;as I plan to start the fuselage before 07 comes to an end.
I will be curious to see how that works out for you ( not removing from the building board ). How will you sand the bottom Aileron/Flap Ribs down for the 1/16 cap strips? Keep us posted. As for not responding sooner, I know how that goes, no worries.
I've got the ribs for the Right wing glued together and now I need to fit each of them to the main spar ( sand the angle on them ).
Jim
I WAS TOTALLY WRONG----------> currently adding the cap strips to the ribs and "THEN" will remove wing from the building board,'per instructions-'
Ok,, wheel pants were trimmed from the bottom hopefully will allow better takeoffs on grass. Looking for bigger fuel tank,, 20+ oz would be better size.
Also the farings for the landing gear are held on with small screws. I was tempted to glue it but did not. The small screws don't hold well in the thin sheeting so I put glue on each screw and lightly tightened. Working well.
IL, USA Status: offline
For the fairings, I know you're given the option of using Glue or Screws however. In that past when dealing with thin sheeting I've been known to go ahead and put the screws in so I have a pilot hole. Then remove the fairing and use Sullivan Ny-rod (yellow color with splines) and cut like 1/8 - 3/16 pieces and insert with glue into the holes (they'll need enlarging somewhat). Once they are glued in and sanded smooth, your screws will have more to bite into, and should hold much better.
Fast Richard,
Were's those Ailerons & Flaps? Just kidding. I know I'm not looking forward to building them again on the Right Wing. I went ahead and epoxied my joiner box pieces together, now I'm waiting on the epoxy to dry. I'm so tempted to go ahead and start putting Former pieces together for the fuselage, I can't hardly stand it. Like a kid at christmas!!!!!
Jim :the wheel pants thing is interesting;what tires are you using ? BTW thanks for the video,I'm working on uploading it
jaaronO1: thanks for posting the infomation on the wing strut attachment,should be helpful- and YES waiting to build the fuselage IS like being a kid waiting for Christmas
Completed the rib cap strips and will remove wing from board a bit later.
CA, USA Status: offline
Hi Jim: I just caught up with this thread and I must say you covered things very well. This will be a big help in finishing mine. As I read the thread I was wondering if the 150 would be enough for this bird. The 220 would be a great motor for the plane and I will need to read up on the ups and down on the motor. Here is the scheme
