RE: 07 TopFlite Stinson build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: 07 TopFlite Stinson build Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: 07 TopFlite Stinson build - 11/25/2007 3:31:51 AM
jaaron01
Status: offline
Grotesquebass: Dont worry you'll see it plain as day, once you get the formers all glued down. When your instructed to keep a straight line from 5 through 9, you'll see it plain as day.
Here's a couple of photos of how far I've gotten tonight on the fuselage. If you look at the top (which is actually the bottom) it looks like the longeron curve inward. They don't, but due to the curvature downward, the angle of which my camera is makes it look that way. I went back and rechecked them after I looked at the photos on my camera.
Be sure and visit topflites FAQ section on the Stinson, there's some good information there from others who have had problems. That's were I found the info about the formers.
Jim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Grotesquebass)
       Post #: 176
RE: 07 TopFlite Stinson build - 11/25/2007 7:03:58 PM
Grotesquebass
Status: offline
now thats motivating for me to see well off to get my flap finished looking good dude
_____________________________
"I've got a fever and the only prescription is more cowbell"
(in reply to jaaron01)
       Post #: 177
RE: 07 TopFlite Stinson build - 11/25/2007 7:12:56 PM
jaaron01
Status: offline
I'll post some more pictures this afternoon, but I'll tell you right know I'm not liking how the stingers go on. They don't give you a whole lot to go on, other than, start here; stop there. Even the photos aren't that good. I feel I'll be adding more balsa pieces to the stringers later on so that they blend in better and give a more rounded look to the tail end of the fuselage. I'm going to leave things as they are for now, and see what else happens down the road.
       Post #: 178
RE: 07 TopFlite Stinson build - 11/25/2007 7:24:49 PM
jaaron01
Status: offline
Oh yeah, a word to the wise. When you get to building the fuselage, don't skrim on adding the 1/4 cross bracing. Ensure you add it facing every direction possible. I say this because the photos show some this way, some that way. Once you put on the 1/4 x 3/4 bottom longerons, they have to be bent, and if you've only got your bracing going 1 direction, it will cause the fuselage to bow upwards..etc... You've been warned!!! Have fun.
       Post #: 179
RE: 07 TopFlite Stinson build - 11/25/2007 10:02:22 PM
Grotesquebass
Status: offline
that crossbracing is included with the kit right?
       Post #: 180
RE: 07 TopFlite Stinson build - 11/26/2007 12:35:00 AM
jaaron01
Status: offline
Yes it's included, but if you follow the photo's they show bracing going one way in one photo, then another way in a different photo. Put the bracing both ways forward and backward.
This fuselage is getting rather large, check out these photo's.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 181
RE: 07 TopFlite Stinson build - 11/26/2007 12:49:50 AM
WhoDaMan
Status: offline
You guy's are GOOD
Fly for fun,,,,, Live in Peace
       Post #: 182
RE: 07 TopFlite Stinson build - 11/26/2007 11:59:03 AM
Grotesquebass
Status: offline
damn dude thats looking awsome starting my formers tonite i have not started yet so i am confused which ones are the bracing and which ones are structural.............
< Message edited by Grotesquebass -- 11/26/2007 12:46:35 PM >
       Post #: 183
RE: 07 TopFlite Stinson build - 11/26/2007 8:08:46 PM
jaaron01
Status: offline
Sorry to confuse you. When you get to that point, I'll be here, so I cant explain it a little better. Get some photos' out here. Let's see some others progress other than mine.
Jim
Fast Richard: Where ya at brother?
       Post #: 184
RE: 07 TopFlite Stinson build - 11/26/2007 8:42:36 PM
Grotesquebass
Status: offline
my camera is down waiting on new charger will post pics asap
       Post #: 185
RE: 07 TopFlite Stinson build - 11/26/2007 9:02:54 PM
ramcfarland
Status: offline
VERY CAREFULLY MAKING MY WAY THRU STEP#6 ON RIGHT WING
Keep us posted on the fuselage- BTW in M.A.N.Jan. 2000 there is a build review and mention of "positioning the fuselage wing joiner box.."
gotta walk the dog- will post the comments direct from the magazine review here shortly!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fast Richard
       Post #: 186
RE: 07 TopFlite Stinson build - 11/26/2007 10:05:44 PM
ramcfarland
Status: offline
Hope this is readable - other wise I shall have to 'type it-'
Click for fullsize
Fast Richard
(in reply to ramcfarland)
       Post #: 187
RE: 07 TopFlite Stinson build - 11/26/2007 11:15:44 PM
Grotesquebass
Status: offline
good find richard will note that got formers 3 4 and 5 done glue is drying .........jaaron hows yours coming along?
       Post #: 188
RE: 07 TopFlite Stinson build - 11/26/2007 11:22:59 PM
jaaron01
Status: offline
FUSELAGE ASSEMBLY
Article is as follows:
Building the fuselage begins by laminating and framing bulkheads 3 through 9. Take your time; this assembly will ensure that your fuselage will be built square later. We used slow Zap here. Place the main stringers over the plan, then the bottom bulkheads 3 through 9. As you proceed, use a square to be certain the formers are vertical. Each former is braced by 1/4inch-square balsa to ensure alignment. Care must be taken here, as some of the bracing is permanent and some is removed later. Before you position the bottom stringers, place a straightedge from former 5 to 9 along both sides; this should be straight; if it isn't, remove any high spots. We had to remove 1/4 inch from former 6 and 1/8 inch from 7. Now go ahead and place all the bottom longerons and Zap them into place.
When the bottom of the fuselage is complete, add the top formers, along with the stringers, keeping all the formers straight. The next step is to build the forward fuselage sides; there is a left and a right side, which will build in the right thrust and downthrust that is called for. When this is complete, go ahead and put on the stabilizer and the vertical fin, making sure that everything is square and level. Now it's time to add the wing to the fuselage by building another joiner box and placing it on top and in front of former 4. I found that the rear mount should be in front of-not behind-former 5; if you place it as shown on the wing plan, it will be too far back. I also added an 1/8-inch-thick aircraft-grade wood spacer to the fuselage rib to strengthen the lite-ply rib where the bolt goes through. (Top Flite has added this modification to subsequent kits.) Now place the assembled wing and fuselage rib with the joiner tube in the fuselage joiner box. Check the measurements from the wing to the tail from both wingtips. If the measurements are OK, go ahead and glue in the joiner box with some Zap 30-minute epoxy. Sheeting the front half of the fuselage is somewhat difficult because the supplied wood is fairly hard, but it's manageable if it is soaked first in ammonia and water. We opted to make both of the model's doors operational solely for the ease of bolting on the wing; these were not difficult to construct.
       Post #: 189
RE: 07 TopFlite Stinson build - 11/26/2007 11:26:39 PM
jaaron01
Status: offline
