RE: 07 TopFlite Stinson build (Full Version)
All Forums >> [RC Airplanes] >> Kit Building
Message
jaaron01 -> RE: 07 TopFlite Stinson build (11/25/2007 3:31:51 AM)
Grotesquebass: Dont worry you'll see it plain as day, once you get the formers all glued down. When your instructed to keep a straight line from 5 through 9, you'll see it plain as day.
Here's a couple of photos of how far I've gotten tonight on the fuselage. If you look at the top (which is actually the bottom) it looks like the longeron curve inward. They don't, but due to the curvature downward, the angle of which my camera is makes it look that way. I went back and rechecked them after I looked at the photos on my camera.
Be sure and visit topflites FAQ section on the Stinson, there's some good information there from others who have had problems. That's were I found the info about the formers.
Jim
Grotesquebass -> RE: 07 TopFlite Stinson build (11/25/2007 7:03:58 PM)
now thats motivating for me to see well off to get my flap finished looking good dude
jaaron01 -> RE: 07 TopFlite Stinson build (11/25/2007 7:12:56 PM)
I'll post some more pictures this afternoon, but I'll tell you right know I'm not liking how the stingers go on. They don't give you a whole lot to go on, other than, start here; stop there. Even the photos aren't that good. I feel I'll be adding more balsa pieces to the stringers later on so that they blend in better and give a more rounded look to the tail end of the fuselage. I'm going to leave things as they are for now, and see what else happens down the road.
jaaron01 -> RE: 07 TopFlite Stinson build (11/25/2007 7:24:49 PM)
Oh yeah, a word to the wise. When you get to building the fuselage, don't skrim on adding the 1/4 cross bracing. Ensure you add it facing every direction possible. I say this because the photos show some this way, some that way. Once you put on the 1/4 x 3/4 bottom longerons, they have to be bent, and if you've only got your bracing going 1 direction, it will cause the fuselage to bow upwards..etc... You've been warned!!! Have fun.
Grotesquebass -> RE: 07 TopFlite Stinson build (11/25/2007 10:02:22 PM)
that crossbracing is included with the kit right?
jaaron01 -> RE: 07 TopFlite Stinson build (11/26/2007 12:35:00 AM)
Yes it's included, but if you follow the photo's they show bracing going one way in one photo, then another way in a different photo. Put the bracing both ways forward and backward.
This fuselage is getting rather large, check out these photo's.
WhoDaMan -> RE: 07 TopFlite Stinson build (11/26/2007 12:49:50 AM)
You guy's are GOOD [:D]
Grotesquebass -> RE: 07 TopFlite Stinson build (11/26/2007 11:59:03 AM)
damn dude thats looking awsome starting my formers tonite i have not started yet so i am confused which ones are the bracing and which ones are structural.............
jaaron01 -> RE: 07 TopFlite Stinson build (11/26/2007 8:08:46 PM)
Sorry to confuse you. When you get to that point, I'll be here, so I cant explain it a little better. Get some photos' out here. Let's see some others progress other than mine.
Jim
Fast Richard: Where ya at brother?
Grotesquebass -> RE: 07 TopFlite Stinson build (11/26/2007 8:42:36 PM)
my camera is down waiting on new charger will post pics asap
ramcfarland -> RE: 07 TopFlite Stinson build (11/26/2007 9:02:54 PM)
VERY CAREFULLY MAKING MY WAY THRU STEP#6 ON RIGHT WING[:D][:D][:D]
Keep us posted on the fuselage- BTW in M.A.N.Jan. 2000 there is a build review and mention of "positioning the fuselage wing joiner box.."
gotta walk the dog- will post the comments direct from the magazine review here shortly!!
ramcfarland -> RE: 07 TopFlite Stinson build (11/26/2007 10:05:44 PM)
Hope this is readable -[;)] other wise I shall have to 'type it-'[:D]
Grotesquebass -> RE: 07 TopFlite Stinson build (11/26/2007 11:15:44 PM)
good find richard will note that got formers 3 4 and 5 done glue is drying .........jaaron hows yours coming along?
jaaron01 -> RE: 07 TopFlite Stinson build (11/26/2007 11:22:59 PM)
FUSELAGE ASSEMBLY
Article is as follows:
Building the fuselage begins by laminating and framing bulkheads 3 through 9. Take your time; this assembly will ensure that your fuselage will be built square later. We used slow Zap here. Place the main stringers over the plan, then the bottom bulkheads 3 through 9. As you proceed, use a square to be certain the formers are vertical. Each former is braced by 1/4inch-square balsa to ensure alignment. Care must be taken here, as some of the bracing is permanent and some is removed later. Before you position the bottom stringers, place a straightedge from former 5 to 9 along both sides; this should be straight; if it isn't, remove any high spots. We had to remove 1/4 inch from former 6 and 1/8 inch from 7. Now go ahead and place all the bottom longerons and Zap them into place.
When the bottom of the fuselage is complete, add the top formers, along with the stringers, keeping all the formers straight. The next step is to build the forward fuselage sides; there is a left and a right side, which will build in the right thrust and downthrust that is called for. When this is complete, go ahead and put on the stabilizer and the vertical fin, making sure that everything is square and level. Now it's time to add the wing to the fuselage by building another joiner box and placing it on top and in front of former 4. I found that the rear mount should be in front of-not behind-former 5; if you place it as shown on the wing plan, it will be too far back. I also added an 1/8-inch-thick aircraft-grade wood spacer to the fuselage rib to strengthen the lite-ply rib where the bolt goes through. (Top Flite has added this modification to subsequent kits.) Now place the assembled wing and fuselage rib with the joiner tube in the fuselage joiner box. Check the measurements from the wing to the tail from both wingtips. If the measurements are OK, go ahead and glue in the joiner box with some Zap 30-minute epoxy. Sheeting the front half of the fuselage is somewhat difficult because the supplied wood is fairly hard, but it's manageable if it is soaked first in ammonia and water. We opted to make both of the model's doors operational solely for the ease of bolting on the wing; these were not difficult to construct.
jaaron01 -> RE: 07 TopFlite Stinson build (11/26/2007 11:26:39 PM)
Grotesquebass: I'm gluing in the Stab Saddle area tonight. Then I'm going to start in on the front (engine box & firewall).
I might slow down for a few days, and let some other builders get caught up.
Jim
WhoDaMan -> RE: 07 TopFlite Stinson build (11/27/2007 1:10:19 AM)
Hi Jim:
I need to get some wheels for my bird,,, Any idea's
Someone also asked what glass the plane has, They were with the kit I purchased and I believe they are Fiberglass specialty's
Dave
Grotesquebass -> RE: 07 TopFlite Stinson build (11/27/2007 1:53:15 AM)
dude this thread has taken off ALOT of good info in here i have all my formers done will begin construction tomorrow
jaaron01 -> RE: 07 TopFlite Stinson build (11/27/2007 2:36:36 AM)
For wheels it really depends on your personal preference. Obviously 5' tires are a minimum, but I like the fat look that you get with dubro piper cub tires. The down side to those is you'll have to enlarge the wheel pants inside to ensure they don't rub, and also make sure you have your wheel collars really close so the wheel doesn't move side to side and rub the wheel pants. If you don't have a preference I'd go with the dubro 5'normal size tires. The part number is in the front of the topflite book.
I took tonight off from building, but tommorrow I'll finish the stab saddle and begin the front engine area.
Jim
Grotesquebass -> RE: 07 TopFlite Stinson build (11/27/2007 2:43:44 AM)
hey guys question on covering and paint i plan on using 21st century fabric....can this stuff be painted?, does it need to be primed? and is that klasskote stuff any good i am a ways from painting just wanna have all the ifo for when the time comes thanks........
WhoDaMan -> RE: 07 TopFlite Stinson build (11/27/2007 4:48:43 AM)
Thank you Jim
Dave
Grotesquebass -> RE: 07 TopFlite Stinson build (11/27/2007 1:18:58 PM)
quote:
ORIGINAL: jaaron01
Jim
i am at that point dude i am installing formers have 3 and 4 set up as of now ....
red1 -> RE: 07 TopFlite Stinson build (11/27/2007 6:54:25 PM)
Hi Fast Richard,
I have a TF Stinson SR-9 kit awaiting my finishing up my H9 AT-6 assembly(its an ARF). I also have a Pica Waco YMF-3 kit awaiting.
Pardon my ignorance. What are those black things your T pins appear to be stuck through?
Red 1
AMA IMAA
Waco Brotherhood *72
Grotesquebass -> RE: 07 TopFlite Stinson build (11/27/2007 8:00:10 PM)
red1,
welcome to the thread it is slowly but surely becoming loaded with great info the stinson has been a fun project so far and has taught me alot you will enjoy it
Bryan
WhoDaMan -> RE: 07 TopFlite Stinson build (11/27/2007 8:02:10 PM)
Hi Richard, My frien went down to Texas and took some photo's of the real bird, It may take me a year just to do the cockpit [:D]
ramcfarland -> RE: 07 TopFlite Stinson build (11/27/2007 8:32:55 PM)
If I do an SR-9 it will be a result of wanting to replicate the gorgeous instrument panel its as they say"awesome!"
Well sat down at the bench for a while ignored another project and quickly proceeded to step #13 plan on Starting the attachment of the leading edge 3/32' sheeting here real soon.
It is great to watch this thread grow as I go so slow..............[;)]
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.6875
