RCV .58CD stops when handtrowen
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  9/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> RCV .58CD stops when handtrowen
Page: [1]
Login
RCV .58CD stops when handtrowen - 9/27/2007 1:26:07 AM
RegRegister
Status: offline
I have a RCV .58CD in a Kyosho Calmato trainer. Using a 12x6 APC and Model Technics fuel with 10% Nitro and 18% syntetich oil.
The engine has now run for about 45 min and seems to run fin when on ground.
The problem is: when i handtrow the airplane the engine stops. Seems like at cant take the change in speed.
Tried to set main needel very rich, but it did not solve the problem. Also tried not to have full speed. Stoped the trottel from opening with ca. 1,5mm.
       Post #: 1
RE: RCV .58CD stops when handtrowen - 9/27/2007 2:28:28 AM
shonny
Status: offline
Det er flere muligheter, men det som umiddelbart kommer opp er at du har litt for mager blanding, dvs at motoren ikke har nok drivstoff.
Skru opp justeringen 1/4 til 1/2 omdreining og se da.
Dette er norsk, - THE BEST!
shonny
(in reply to RegRegister)
       Post #: 2
RE: RCV .58CD stops when handtrowen - 9/27/2007 12:43:59 PM
RegRegister
Status: offline
Hei shonny
Vet godt at min engelsk ikke er helt på topp.
Stilte hoveddysa så rik at motoren hadde problemer med å gå på fullt turtall. Vanskelig å tro at den kan stilles rikere.
Har hatt samme problem med 2 takt og da var det for mager blanding.
Har kansje et problem som ikke dukker opp så veldig ofte da svært få håndstarter flyene.
Har en følelse av at motoren ville oppført seg greit om flyet ble startet på hjulene.
Trying to explain in norwegian that i think the engine wold work ok if I started the plain on wheels. But then i need a runway.....
(in reply to shonny)
       Post #: 3
RE: RCV .58CD stops when handtrowen - 9/27/2007 2:46:58 PM
shonny
Status: offline
Hadde ikke noe med engelsken din å gjøre. Liker å erte alle som ikke snakker annet enn engelsk.
Og vær ikke bekymret, engelsken din er en masse bedre en de fleste fra 'over dammen'.
Det neste med motoren blir å kjøre den litt magrere da, for 'hand launching' skulle ikke gjøre noen forskjell i seg selv.
This was just to get the curious ones (if there are any) off the scent
Learning different languages is tops! (As is aeromodelling)
shonny
< Message edited by shonny -- 9/27/2007 2:53:31 PM >
       Post #: 4
RE: RCV .58CD stops when handtrowen - 9/27/2007 3:16:58 PM
RCV Engines
Status: offline
Hi
Our advise would be to reset your carburettor to factory settings, this is in section 6 of the user manual. Please let us know how you get on.
Many thanks
Stephanie
P.S. Can't comment on the different languages - trying to perfect English!
_____________________________
Technical Support
RCV Engines - UK
       Post #: 5
RE: RCV .58CD stops when handtrowen - 10/21/2007 4:23:51 PM
RegRegister
Status: offline
Hi Stephanie
I did reset carburetor to factory settings and everything is now OK.
Many thanks
RegRegister
(in reply to RCV Engines)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
