RE: 2-cycle oil vs turbine oil
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> RE: 2-cycle oil vs turbine oil
Page: <<   < prev  1 [2]
Login
RE: 2-cycle oil vs turbine oil - 10/4/2007 9:06:58 AM
Boomerang1
Status: offline
Matt PM'd me asking why I slammed JetCat. I explained I was not slamming anyone & there's nothing wrong with the engines, great products & that's why they are market leaders in Oz & probably the US as well.
What would be nice would be for Matt to convey to the factory that people are interested in using other than turbine oil in their Jetcats & that the factory should do some testing so they can recommend an alternative.
After all, 99% of turbines are basically variations on the same design. THe reason for that is what we buy is what works, it's no surprise that they are all similar. If Wrens & Jet Central turbines run on alternative oils & the manufacturers are prepared to warrant the engines when using these oils can someone give me a technical reason why Jetcats cannot? ( I don't consider 'because Jetcat says so' or 'because I use turbine oil & it works' technical reasons.)
If I were to buy another turbine it would most likely be a Jetcat, not that I'm unhappy with my Wren. What would I do? Probably use turbine oil until it was out of warranty & then run something else. - John.
_____________________________
Distributor for: Nothing! So my posts can be unbiased.
(in reply to FalconWings)
       Post #: 26
RE: 2-cycle oil vs turbine oil - 10/4/2007 2:15:34 PM
josecilurzo
Status: offline
excellent explanation Harry! I agree fully, and the John also is correct, however, the manufacturers needs to certify the oil 2T for use, after exhausting tests as he was made with the turbine oil. If I had much money also I would test.
John you use oil 2T with frequency in its engine?
When I said with Jesus Artes, he said that the turbine oil was used by supporting high temperatures and high attrition (bearings), however, it already studied the use of the oil 2T, unhappyly it retired, definitively the father of the microturbines, had the grateful satisfaction of knows him, heard all history of the main turbines and the aid that had had gratuitously of Jesus. Not to generate controversy I prefer not to speak, therefore, today we have excellent turbines, however, thanks to Jesus Artes!
The big engines turn little, therefore, the research with the oil 2T started for the "bigers" ( the first turbine to use oil 2T was an prototype to military use called ELEPHANT!!! ( its a big monster!!! ).
we go changing ideas!!
thank's
José
(in reply to Boomerang1)
       Post #: 27
RE: 2-cycle oil vs turbine oil - 10/5/2007 7:20:36 AM
John H.
Status: offline
I have used 2-stroke oil for years in my two p80s and ram 500s with no problems. Make sure its tcw3 and not tc rated. Tc oils gets very thick when it gets cold or
sits around a long time and starter has hard time turning the engine.
(in reply to josecilurzo)
       Post #: 28
RE: 2-cycle oil vs turbine oil - 10/5/2007 12:48:11 PM
Boomerang1
Status: offline
John H, thanks for the heads up. I checked the specs the best I could for Castrol TTS oil & it is listed as JASCO FC which appears to be the equivalent of TC rating. I had exactly the problem you mentioned, the starter struggled to turn the engine over after it being left for a while. TTS is recomended by Wren but the driving instructions for the engine specify TCW 3 (outboard oil)
Jose, do you mean 2 cycle oil? If that's the case, yes, I put about 3 litres of oil through the engine. - John.
(in reply to John H.)
       Post #: 29
RE: 2-cycle oil vs turbine oil - 10/5/2007 2:56:07 PM
josecilurzo
Status: offline
John,two cycle and 2T oil, is the same 2-stroke oil.
you're already had disassembled the engines to verify the consuming of the bearings, the conditions of the injectors and combustion chamber ?
( I would like that our forum, had the presence of the manufacturers )
jose
       Post #: 30
RE: 2-cycle oil vs turbine oil - 10/5/2007 2:58:54 PM
josecilurzo
Status: offline
I told with Carlos a few days, and he said to me, the EXXON turbine oil, obstructs the injectors.
jose
       Post #: 31
RE: 2-cycle oil vs turbine oil - 10/6/2007 4:59:41 AM
Boomerang1
Status: offline
Jose, no, I have not disassembled my turbine, I'm like 99% of modellers who just turn the key & go. I just rely on the recommendations of my turbine manufacturer - Wren. I'm sure Jetcat service hundreds of engines & base their recommendations on what they feel is satisfactory. At this point in time Jetcat says told turbine oil only.
Perhaps this discussion should be on the general jet forums, not the Jetcat specific forum, as Jetcat has made it's position clear. I'm sure there is one already about alternative oils. - John.
       Post #: 32
RE: 2-cycle oil vs turbine oil - 10/6/2007 12:47:59 PM
josecilurzo
Status: offline
Hi John,
I agree total to you, and I find that we do not have to lock up the discussion, and to open a new in the general jet forum.
How many hours, and, I do that
how many hours has your engine of functioning with 2-stroke oil ?
I go to open a specific forum ( in general jet forum ) to try to continue to this, I hope that the guys ahead the discucion!!
jose
       Post #: 33
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.047RCU3
