dvs1
UT, USA Status: offline
quote:
Hi dvs1; Have been following the building thread for a while. Keep up the great effort it certainly is appreciated. Had a chance to order one of these models at a recent show and is due in on the next shipment. (One of my upcoming winter projects). Much like yourself I wanted to stay with a gasoline engine for this model. Wanted to know your thoughts between the Evolution 26 and the BCMA 26 you will be putting in your model. I was leaning toward the Evolution engine but wanted a chance to discuss this before purchasing either one. From what I have read the weight should be close, the Evolution is indicated at 33.6 oz without muffler and the BCMA is at 36 with ignition and muffler. Was it weight, size, hp, cost, fit inside the cowling, etc. One last thing if possible, what is the approx. diameter of the cowling where the engine will sit. Thanks again for the thread. Regards Randy Randy, I highly considered the evolution 26 but in the end it was the money factor that made me purchase the BCMA26. Weight is not a factor, acually both engines really don't weigh quite what I wanted for this tail heavy plane. But these are the only two I really found that I think will fit entirely in the cowl, and that was the main thing for me was a hidden engine. Both will spin comparable sized props. One thing I did want to get away from was the cradle type engine mount the Evolution uses. I wanted to use a engine like the BCMA that uses standoffs or mounts directly to the firewall. I did contemplate using the BCMA40 as just a small portion of the head would stick out and I would be able to use a scale prop. But I really am trying to get away from engine parts bulging from cowls. I think its 6's either way, from my calculations Both SHOULD fit completely inside the cowl and both are good engines, and like I said in the end it was cost for me. I also figured if I need just a little more room for the plug boot I can rotate the engine and fit the boot in the cowl blister. The cowl diameter where the engine will be placed is just at or under 8.5 inches. If you have any other questions let me know and post some pics when you start your build. I like to see how other people are coming on theirs as well and see any mods they are doing. Later, Curt
