RE: KMP / YT FW-190 Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP / YT FW-190 Build Thread
Page: <<   < prev  9 10 11 12 13 14 15 [16] 17 18   next >   >>
Login
RE: KMP / YT FW-190 Build Thread - 2/22/2008 2:13:07 AM
MANFRED
Status: offline
dat low grade silicone compund will melt or crack apart. I can't even get those to work on a 4 stroke.
_____________________________
Life is too short to fly ugly planes!
(in reply to mobyal)
       Post #: 376
RE: KMP / YT FW-190 Build Thread - 2/22/2008 7:11:50 AM
Redback
Status: offline
Hi Al,
Tailwheel is Dubro Cat No 957. Picture is below. I added a couple of light springs between the wheel assy and the bracket, also had to extend the shaft to fit the pull-pull. Was able to do all the instal through a hole cut in the rudder post.
Regards
Terry
Click to see fullsize image.
Click for fullsize
(in reply to MANFRED)
       Post #: 377
RE: KMP / YT FW-190 Build Thread - 2/22/2008 2:00:57 PM
mobyal
Status: offline
Thanks a lot Terry. Neat install and just what I'm looking to do. I'll try to copy yours if you don't mind!
Al
MobyAl
(in reply to Redback)
       Post #: 378
RE: KMP / YT FW-190 Build Thread - 2/23/2008 2:38:21 PM
LDM
Status: online
jd do you have a link for the headers ? I like the hook up , I would probably add Macs flex pipe vs the Dubro , simple fix but 100% assured to take the heat
LDM
       Post #: 379
RE: KMP / YT FW-190 Build Thread - 2/24/2008 9:18:03 PM
Redback
Status: offline
Almost got a maiden flight in yesterday!
Weathers been dry and warm for a couple of days now so things have dried out somewhat. Took the plane down to the club, strip had been recently been cut and was fairly short.
Made a few runs down the strip to see how the plane tracked. Pleasantly surprised to find that it was fairly easy to keep straight, though you do have to keep feeding right rudder in. Not really unexpected as there is no side thrust on the motor.
Couple more runs increasing the speed, beginning to get the feeling that this bird actually wants to fly (all 17.4lbs of it!). When it became apparent where the flying weight was headed I had some concerns about whether the 120AX had enough guts for the job, less worried now having seen the way it accelerated. Comes up onto the mains nicely and looks ready to fly with a bit more speed.
Looking good for a first flight once the sun gets up a bit (early on it's right in your face, either for take off or landing - don't need that for a 1st flight!).
Then discover the retracts, which had been working fine at home are giving problems. Seems like the air pipe to the wing is getting constricted as they work OK with the wing off, but it's not obvious where. After fiddling a bit I decide that it's a workshop job. Could have flown with the wheels down but decide to chicken out for today.
All in all I'm happy with the day's result, and am starting to think that we may have a flying brick at least. Will sort out the retracts in the week and aim for next Sunday. Since I have now unretired (again) I can afford the hobby but don't have time to pursue it!
Terry
(in reply to LDM)
       Post #: 380
RE: KMP / YT FW-190 Build Thread - 2/25/2008 10:46:44 PM
jddickers
Status: offline
LDM, I got the header off E-Bay. I will find his info and post it. I am going to change the dubro elbows they were easy to use in setting up the exaust. When they burn out I will change to the Macs flex.
JD
       Post #: 381
RE: KMP / YT FW-190 Build Thread - 2/25/2008 10:52:33 PM
Evil_Merlin
Status: offline
I talked with Andrew Kondor at WRAM this weekend.
The Fw 190 is getting a full fuse rework. I guess my words finally found some impact someplace.
As I said in the other thread, I talked with him as he was selling his 3 bladed props like a mad man.
(in reply to jddickers)
       Post #: 382
RE: KMP / YT FW-190 Build Thread - 2/25/2008 10:55:19 PM
ticketec
Status: offline
Hey Evil,
Sound great!!! great to see that they have listen to those who have let them know how far off the mark they were!
What 3 blade props is he selling?
dave
(in reply to Evil_Merlin)
       Post #: 383
RE: KMP / YT FW-190 Build Thread - 2/25/2008 11:12:19 PM
LDM
Status: online
Thanks JD , keep me posted , you wont be disappointed with Macs product , you can call them when needed and they will let you know what to order for the job at hand .
Evil thanks for the offer on the Pms when I start my build , I will take you up on the offer . I am planning on a sliding canopy , and all the retracts , doors ect .
All i need to purchase is my servos , full bodied pilot and gas tank for the G26ei that power this thing . I am considering doing the wing in flite skin vs traditional fiberglass
LDM
(in reply to ticketec)
       Post #: 384
RE: KMP / YT FW-190 Build Thread - 2/26/2008 4:34:08 AM
Evil_Merlin
Status: offline
Yep, I may have to take back most of the smack talking if they do fix the issues.
The props were KMP Signature Props, all three bladed, from 14x8 to 16x13. Good looking flight props in my honest opinion.
LDM, just keep in touch and I'll give you all I can.
       Post #: 385
RE: KMP / YT FW-190 Build Thread - 2/26/2008 10:43:47 AM
nicostoffi
Status: offline
Here some pics out of the working room.
See also a little videoclip from break-in of the Saito 170.
http://media.putfile.com/Test-Saito-170
Click for fullsize
Click for fullsize
Click for fullsize
.... and always the sun at my back
www.stkl-online.de
       Post #: 386
RE: KMP / YT FW-190 Build Thread - 2/26/2008 3:48:52 PM
MANFRED
Status: offline
That sounds and looks awesome!
(in reply to nicostoffi)
       Post #: 387
RE: KMP / YT FW-190 Build Thread - 2/26/2008 4:38:27 PM
Ompa
Status: offline
mmmm, like that sound
No Guts No Glory
       Post #: 388
RE: KMP / YT FW-190 Build Thread - 2/28/2008 5:38:10 PM
Ompa
Status: offline
Today when i got home from work there was a little package in my mailbox. It was my new Sierra Tailretract for my FW-190
No Guts No Glory
(in reply to Ompa)
       Post #: 389
RE: KMP / YT FW-190 Build Thread - 2/28/2008 9:48:17 PM
mobyal
Status: offline
And I got word from KMP today that they're shipping my spinner.... Black anodized made by Tru Turn for the FW190.
I went for the 2-blade, as neither Paul nor I were sure which if any of their 3-blade props was suited to the OS125ax I'm going to use.
MobyAl
(in reply to Ompa)
       Post #: 390
RE: KMP / YT FW-190 Build Thread - 2/28/2008 10:12:31 PM
Evil_Merlin
Status: offline
OS recommends 14x10 and the 15x6 two bladed, the rule of thumb I use, is take 1-2" from the diameter and add 1-2" to the pitch to move from 2 bladed to 3 bladed props.
I bet this one would work fine: http://www.kmp.ca/product_info.php?cPath=27_31&products_id=172&osCsid=32c220bad062443647574fbf491bf446
< Message edited by Evil_Merlin -- 2/28/2008 10:14:33 PM >
       Post #: 391
RE: KMP / YT FW-190 Build Thread - 3/1/2008 2:06:51 PM
Ompa
