H8Basher -> RE: KMP / YT FW-190 Build Thread (10/10/2007 6:54:53 AM)
quote:
ORIGINAL: bigtim what radio/servos are you guys using for this plane, does it require HD or will standard servos suffice,I am also looking forward to seing the gear that comes with it. I might have to sell off some of my kits to get one of these its looking better every time I check back here,I also happen to have a BCMA 26 that looks like it would fit in that cowl nicely. I think standard servos would be fine. The kit is set up to use separate servos for each individual control surface (even one for each elevator) I am actually going to change it to one servo for the elevator as I didn't like the friction from the supplied elevator setup and am going to use a single split carbon pushrod. In that case I will be using a higher torque servo. I will also use a high torque servo for rudder, to handle the load from the tailwheel. For the flaps, I plan to use the hitec standard digital servos, so I can program one reversed, and also slow down the speed.
