Evil_Merlin
MA, USA Status: online
Probably to keep the costs as low as possible. Not like that is saying a lot with the Serria gear... You need to set up some type of down link (the top scissor) on the struts. It adds so much more to the plane. Its actually easy to set up one. Think of it this way, take two light pieces of blasa. Attach in the middle on a hinge of some type (robard mini-pin hinge maybe?). Make sure it can only bend in one direction (so it cant foul gear retraction)Attach the bottom to the strut in a manner similar to the gear door. For the part of the strut that runs up and into the wheel well, round the end of it. When the gear comes down, by gravity alone, the down link will unfold automatically. When the gear retracts the rounded edge of the top of the link will act as a type of runner, collapsing the downlink on itself. Cheap, easy to do, and if something really goes wrong, the balsa struts used for the downlink will snap away and not mess things up too bad... Careful with the tig, I don't know much about it, but heating those struts from KMP would be a bad thing as they look thin and probably wouldnt' handle the heat too well. You could actually just directly attach the door to the strut and build up the collars out of plastic or something.
< Message edited by Evil_Merlin -- 10/22/2007 9:28:36 PM >
