dvs1
UT, USA Status: offline
quote:
KMP FW-190 Builders, I have not worked out a price for the tail retract yet but it would be between $75.00 and $100.00 depending on the final quantity. The thing I would like someone to work out is how we would mount the tail unit. Without cutting the tail off the plane, how do we get a former for the retract mounted and a rib in the vertical fin to mount the cylinder to. If anyone has any ideas, I'm all ears. Thanks, Darrell Darrell, Thanks for posting. Since I brought the idea up to you, I will cut open a scale size opening in mine tonight (I'm not scared ) Then by looking inside I might have a better answer. I'll post a pic when I'm done. Depending on how wide the hole is you could probably fit a former in the fuse but it might have to be a two piece and then epoxy together when in the fuse. As far as the rib in the vertical fin how high from the bottom of the fuse do you need it to be. Depending on where it needs to be you might be able to cut a small hole in the back of the fin and slide in a former. I might be way off here though. But either way I'm cutting into the bottom of my fuse because one way or another I would like the tailgear in the proper place. The pull-pull cables system may be interesting as well. Just my personal preference but I would rather pay a little more and have a higher quality more detailed gear set up. Again thanks for your time Darrell.
