RE: KMP / YT FW-190 Build Thread (Full Version)
All Forums >> [RC Airplanes] >> RC Warbirds and Warplanes
Message
Airscrew -> RE: KMP / YT FW-190 Build Thread (10/30/2007 9:00:22 AM)
Yes, I'm interested in a tailwheel from Sierra. But first I need a kit from this bird and that seems not to be easy!
KMP and other Shops don't ship to Switzerland[:(] So I hope one of you can do this for me. I would pay with PayPal.
Dieter
MANFRED -> RE: KMP / YT FW-190 Build Thread (10/30/2007 3:47:55 PM)
Curt, did Darrell give you a ballpark for the tailgear?
dvs1 -> RE: KMP / YT FW-190 Build Thread (10/30/2007 7:22:29 PM)
He didn't give me an exact quote, he just said the price would be about the same
as similar sized tailgear. So I would say around $150, (but that could be a high number)
He could definately tell us if we can get enough people that want them.
BigRetracts-RCU -> RE: KMP / YT FW-190 Build Thread (10/30/2007 8:08:09 PM)
KMP FW-190 Builders,
I have not worked out a price for the tail retract yet but it would be between $75.00 and $100.00
depending on the final quantity.
The thing I would like someone to work out is how we would mount the tail unit.
Without cutting the tail off the plane, how do we get a former for the retract mounted and a
rib in the vertical fin to mount the cylinder to.
If anyone has any ideas, I'm all ears.
Darrell
dvs1 -> RE: KMP / YT FW-190 Build Thread (10/31/2007 12:45:58 AM)
Darrell
Darrell,
Thanks for posting. Since I brought the idea up to you, I will cut open a scale size opening in mine tonight (I'm not scared[:D])
Then by looking inside I might have a better answer. I'll post a pic when I'm done. Depending on how wide the hole is you could probably
fit a former in the fuse but it might have to be a two piece and then epoxy together when in the fuse. As far as the rib in the vertical fin
how high from the bottom of the fuse do you need it to be. Depending on where it needs to be you might be able to cut a small hole in the back
of the fin and slide in a former. I might be way off here though. But either way I'm cutting into the bottom of my fuse because one way or
another I would like the tailgear in the proper place. The pull-pull cables system may be interesting as well.
Just my personal preference but I would rather pay a little more and have a higher quality more detailed gear set up.
Again thanks for your time Darrell.
Helijet -> RE: KMP / YT FW-190 Build Thread (10/31/2007 1:21:24 AM)
Hi Guys
Question : for those that have already received their kits what did you pay and when did your KMP FW 190 kit arrive?
Dean W.
dvs1 -> RE: KMP / YT FW-190 Build Thread (10/31/2007 2:34:40 AM)
quote:
Hi Guys
Dean W.
Around $685 shipped, received it about a month ago, shipping took forever, took over a week by DHL.
dvs1 -> RE: KMP / YT FW-190 Build Thread (10/31/2007 2:39:55 AM)
Darrell,
Did a rough cutout tonight for a future tailgear. Pretty hollow in there. But after seeing what has been done
in the past by some people I still think it is definately possible.
Also for those mounting factory tail wire to bottom of fuse be careful, When I cut mine out I noticed that it was way off center
and there was a large glob of hot glue between bottom of fuse and plywood the gear bracket is supposed to mount too. The glue was
over 3/8 of an inch thick so the gear would have attached to glue instead of wood.
propwashed -> RE: KMP / YT FW-190 Build Thread (10/31/2007 6:00:51 AM)
How goes it.. The 190 is looking nice. As for the access for the tailwheel formers you need to install...If you don't hinge the rudder first you can carfully cutout the reaer vertical hinge former cut out your access retract hole (like you have done) and then do as we have to on the SisT kit
First shape and install your front lower support and then install the upper/cylinder support between the vertical fin sides. Would need the gear on hand to fit all the formers correctly..
Tripp
shafs -> RE: KMP / YT FW-190 Build Thread (10/31/2007 6:24:38 AM)
Hi i paid 627au for my fw to get to the front door.
shafs
Lplus -> RE: KMP / YT FW-190 Build Thread (10/31/2007 9:37:19 AM)
Thanks for the heads up about the tail wheel mounting, dvs1. I won't bother with a retracting wheel but will try to make up somethng better looking.
mobyal -> RE: KMP / YT FW-190 Build Thread (10/31/2007 1:35:22 PM)
quote:
ORIGINAL: dvs1
quote:
Hi Guys
Dean W.
Same here...
That's about what I paid, if I remember correctly. Maybe a little more. Got mine from Tomas. Took about a week for it to get here. Ordered the retracts from Darrell @ Sierra on a Friday and they were here on the next Monday.
MANFRED -> RE: KMP / YT FW-190 Build Thread (10/31/2007 3:18:34 PM)
Darrell, is it possible to produce a scale looking strut without the retract unit? This might be a little easier to install.
Sarah -> RE: KMP / YT FW-190 Build Thread (10/31/2007 10:51:28 PM)
Hi Guys,
Could someone be kind enough and post the box dimensions for the FW190 please.
Many thanks,
Sarah
mobyal -> RE: KMP / YT FW-190 Build Thread (11/1/2007 1:14:42 AM)
quote:
ORIGINAL: Sarah
Hi Guys,
Many thanks,
Sarah
I'll be going over to my shop tomorrow and will measure it then. If you haven't heard from anyone else, I'll post the dimensions for you tomorrow afternoon....
Al
dvs1 -> RE: KMP / YT FW-190 Build Thread (11/1/2007 1:51:38 AM)
quote:
Hi Guys,
Many thanks,
Sarah
Sorry threw my box out but rough estimate is 48X20X16 inches
THESCALEMAN -> RE: KMP / YT FW-190 Build Thread (11/1/2007 2:14:55 PM)
anyone tell me the dia. across the cowl?...thanks...will it take a flat twin?
cheers
dave
mobyal -> RE: KMP / YT FW-190 Build Thread (11/1/2007 2:19:55 PM)
quote:
ORIGINAL: THESCALEMAN
cheers
dave
Headed to the shop now. Will measure it and let you know this pm.
Al
ticketec -> RE: KMP / YT FW-190 Build Thread (11/1/2007 4:53:14 PM)
quote:
ORIGINAL: mobyal
cheers
dave
Al
Hey Mobyal,
Did you get my PM regarding the shipping?
thanks
dave
dvs1 -> RE: KMP / YT FW-190 Build Thread (11/1/2007 7:41:15 PM)
cheers
dave
Slightly over 8.5 inches
mobyal -> RE: KMP / YT FW-190 Build Thread (11/1/2007 8:20:05 PM)
cheers
dave
From front to rear it's 9 1/4" long on the top, 7 7/8" long on the bottom. From side to side, interior is 7" at the front, 8 5/8" rear top and 7 1/2" rear bottom.
Have no idea whether it'l take a flat twin.
Al
THESCALEMAN -> RE: KMP / YT FW-190 Build Thread (11/1/2007 8:21:32 PM)
many thanks dvs1/mobyal.......my saito T182 twin will fit in very nice........
my twin is under 8" dia........
mobyal -> RE: KMP / YT FW-190 Build Thread (11/1/2007 8:21:47 PM)
quote:
ORIGINAL: Sarah
Hi Guys,
Many thanks,
Sarah
Sarah --
The shipping box is 19" by 16" by 50".
Al
mobyal -> RE: KMP / YT FW-190 Build Thread (11/1/2007 8:27:40 PM)
Dave --
I got your pm. Tomorrow am I'll take the box to the PO and get the prices for the various shiipng options and PM you the info.
Al
Sarah -> RE: KMP / YT FW-190 Build Thread (11/1/2007 10:18:52 PM)
quote:
ORIGINAL: mobyal
quote:
ORIGINAL: Sarah
Hi Guys,
Many thanks,
Sarah
Sarah --
Al
Hi MobyAL,
Thank you for posting the box dimensions. I want to see if I can bring one back to England when I go on vacation.
Regards,
Sarah
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.328125
