Cool Power in ABC engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Cool Power in ABC engine
Page: [1]
Login
Cool Power in ABC engine - 9/28/2007 3:07:17 PM
monkeygutz69
Status: offline
I just purchased a Tower Hobbies .75 ABC engine. The Manual recommends castor /synthetic mix. I have 2 gallons of Cool Power 15%, which is all Synthetic. Question... Do I add castor or just run it a bit rich, or give away the 2 gallons and get Omega 15%????
p.s. I use CP MV 15% in my Saitos and they seem to run well. Thanks, Monkey Gutz
_____________________________
Old School Power..If a little bit is good.. a whole bunch is better..and to much still ain't enough!
       Post #: 1
RE: Cool Power in ABC engine - 9/28/2007 9:53:44 PM
XJet
Status: online
Yes, you *can* add some castor.
The problem is that For break-in you probably want to raise the castor level to at least 6%-10% which will mean that your total oil content will increase to 24-28% by volume. This would do for break-in but would be unnecessarily messy and rob you of power for general running.
One thing to consider however is that the 75 is an ABC with quite a bit of pinch and (like all ABCs) should always be run using fuel that has some castor in it.
Yes, some folks do run their ABC engines on fuel with straight synthetic oil -- but those engines won't last as long and are at far more risk of damage from a lean run than engines that have a little castor passing through them.
If I were you, I'd just go out and buy a jug of Omega.
When I'm not here, I'm at RCModelReviews
(in reply to monkeygutz69)
       Post #: 2
RE: Cool Power in ABC engine - 9/29/2007 1:19:17 AM
w8ye
Status: offline
You can buy a pint bottle of Klotz Beno or Sig castor at the hobby shop to add to your cool power to use it up?
If you are just going to do it once or twice, buy some castor oil at wally world or the discount drug store. Usually the drug store stuff costs more if you are going to use it in every gallon of fuel.
I've attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to XJet)
       Post #: 3
RE: Cool Power in ABC engine - 9/29/2007 3:46:04 AM
monkeygutz69
Status: offline
Thanks for the quick replies, guys. I called up the LHS ( where I got the fuel) and asked if they had any castor. The answer was maybe in a week or two. I told them what was going on and they said come on down and swap out. So now I have 2 gallons of Omega 15%. Hopefully alll is right with the world now.... Thanks again... Best Regards, Monkey Gutz
(in reply to w8ye)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
