Aileron-rudder mix
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Polks Hobby >> Aileron-rudder mix
Page: [1]
Login
Aileron-rudder mix - 9/28/2007 4:52:57 PM
flyer495th
Status: online
I have a question concerning this. I can only ge it to work if the values for right & left are different. If I set them for the save value example 10% right & left. When the switch is enabled a beeping sound is heard. If the values are set to 10% and the other to 11% everything is OK. I am just checking to see if others have this also.
Thanks for looking!
PS; This is a tracker III with the version 1.37.5 software
< Message edited by flyer495th -- 9/28/2007 5:02:33 PM >
       Post #: 1
RE: Aileron-rudder mix - 9/29/2007 5:34:43 PM
nobodytwo
Status: offline
For what it's worth, a reasonable percentage mix for rudder aileron, is one to one or 100%. I suggest that you consider using a "P" mix and use 100% for both throws.
I have found that the built in mix is only 50% at best, and will cause the radio to lock up if set any greater than 50%.
Happy Landings
Greg Shane
_____________________________
Greg Shane
(in reply to flyer495th)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.219RCU1
