A bit of help/4 Stroke....what did I Do?
Tower Hobbies
Logged in as Guest
  Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $99.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> A bit of help/4 Stroke....what did I Do?
Page: [1]
Login
A bit of help/4 Stroke....what did I Do? - 9/29/2007 1:12:15 AM
ZoomZoom-RCU
Status: offline
This is for all of you folks who have some experience with 4 strokes. I was just recently geraing up to test run my new out of the box Magnum 52 4 -stroke engine. Got everything ready, installed the prop, then noticed some stiffness when trying to rotate the prop. I thought this odd on a brand new motor, so I backed off and slowly tried to complete a revolution again. This culminated in the prop getting very tight as I tried to rotate it, then a sharp popping sound and it spinning free. No fuel lines were connected this was just a dry run so there was no hydro lock involved. Well, needless to say by this point I was concerned and removed the header, only to find one of the valves stuck....very stuck....compressed down onto its lifter spring and not moving. Long story short, some gentle persuasion with a small screwdriver after applying some lubricant, eventually freed the little #$%@#, and now both of them operate properly and freely....rocking away to their little hearts content as I spin the prop. Now my question....could turning this thing over with a valve stuck as it was, have damaged it? Im a bit concerned even though everything seems to be operating correctly now. I'm getting ready to bench run it tomorrow, but was wondering if there is anything I should be concerned about...or look for? Thanks to all for any assistance.....I could send it in for repair/inspection....but if you guys think there is little chance of real harm having been done, I will run her.
ZZ.
_____________________________
PAY NO ATTENTION TO THE MAN BEHIND THE CURTAIN!
       Post #: 1
RE: A bit of help/4 Stroke....what did I Do? - 9/29/2007 3:59:26 AM
Wayne22
Status: offline
it sounds like the piston was hitting the valve which could bend the valve stem. If you still have the new engine waranty, sent it back.
All I ask is for a chance to prove that money can't make me happy......
(in reply to ZoomZoom-RCU)
       Post #: 2
RE: A bit of help/4 Stroke....what did I Do? - 9/29/2007 2:00:31 PM
ZoomZoom-RCU
Status: offline
Thats what I was afraid of. I'll see if I can return it for service.
ZZ.
(in reply to Wayne22)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
