da Rock
NC, USA Status: offline
quote:
ORIGINAL: js3 Mike, I am a musician not an aerodynamicist. Model airplanes are my hobby, not my profession so you may wish to take my comments with a healty tablespoonful of salt. Hey, I'm retired, so take that into account. It's my excuse when I say anything wrong. grin quote:
That said, my understanding is that the smaller the angle between two surfaces, the greater the drag. Actually that is sorta right, but not completely. Any time there is a "kink", joint, change of direction, whatever........ As the angle goes from 179degrees to 1degree, the drag increases. However, when the angle goes less than 90degrees there is additional drag generated, and it's at a faster rate than it increased from 179 to 90. quote:
Using your examples, I would think the third (bottom) example would have the least amount of drag, the second example would have the most and the first (top) would be somewhere in between. You want to avoid angles equal to and less than 90 deg. Personally, I like the looks of the third example. The 2nd from the top would have more drag than the 3rd. The acute angle is the reason. And I like the third too.
