chris6414
PA, USA Status: offline
quote:
ORIGINAL: RJO I nned help! I have tried everything I know in my limited ability and I cannot stop this thing from vibrating. Its ok past initial spin up and its almost unnoticable at hover but landing and powering down it looks like its going to rattle itself apart! Help! Ive balanced the blades and changed everything I can think of except the main shaft! Where are the vibes? Tail=Tail shaft or really out of balance blades, Head- Mains way out of balance or CG out, Main shaft bent (yes even new ones), Paddles not level, Main gear out of round and and mesh too tight. Paddles not level with one another, bent feathering shaft, warped blade etc. I have one of those scales and I balance my paddles, mains and tail blades withing 1/100th of a gram and no or very little vibes as long as everything else it snug and true. It is hard to get these things perfect. I found this out while trying aerial video and i chased a vibe for two days. Bent main shaft, replaced it then my scale shows up and my out of balance paddles and mains bent my new shaft or it just came bent. TRex hardend shaft is the way to go to elimnate the shaft as a possible cause of the vibe. I tighten all my frame screws as well. After awhile they will loosen up and they hold the bearings in. If it becomes loose, then the bearings will be loose and cause a vibe.
