Druss
AB, CANADA Status: online
if this is your first heli then i doubt you're going to be able to hover it in one spot regardless of how good the components are. plus it's not really that big a heli, you can't hover as easily as a 600 size electric. that being said, i can hover the eflite blade cp in a 3-4' circle. how long have you been flying it? upgraded components like digital servos, better gyro, upgraded metal head parts will help but really do you want to spend that kind of money on this heli? look for any slop in the head, turn the heli off and play with the pieces to see if there is any movement there shouldn't be, mine had a lot of slop in the blade holders which was a loose feathering shaft. you can also replace the stock dampeners with some stiffer ones.
