crashinbash
Joined: 5/3/2005 From: VictoriaB.C., CANADA Status: offline
Hi chopper guy, I found the pictures imbedded in a photo site. they were not for guest veiwers which led me to RCgroups where someone else had also just discovered it. There hasn't been any other information on the internet about this helicopter other than the legitimate pictures which weren't supposed to be found. Esky' seems to keep things under wraps pretty well. Hopefully there will be some information soon. In normal mode for belt CP I fly -2 0 +2 +5 +7 And in Idle up -8 -4 -1 +4 +8 You may want to dumb down the pitch points at max and min if you are not doing 3D, most people would suggest -1,0,2,4,7 and ilde up -7,-3,0,+3,+7 If your blades are not tracking the same pitch you want to correct for that first, you won't get much better range and good flight unless the tracking is dead on first. If you can make them track then I'd say it doesnt matter wich blade you use. If worse came to worse and you couldn't correct for it then I'd use your pitch guage on the higher of 2 blades (the higher pitch range blade than the lesser) cheers
_____________________________
Heli's........ It is your destiny..... and perhaps your demise. http://www.geocities.com/the_b_i_g_01/BIG_RC.html
