Manitou
Joined: 4/20/2008 From: Loma Linda, CA, USA Status: offline
Evdreamer, thanks for the info, I end up using the stock arms of the S3154 and seems to be working ok. I have a Gyro question: I installed a new gyro, Futaba GY401 according to Finless video. When the gyro is on and I move the tail by hand the tail pitch slider moves the right way just like the video. The problem is when I move the rudder stick on the TX, if I move the stick to the left the slider moves right but when I release the stick to return to center stick, the slider does not move back to the middle of the axel. Same thing if I move the stick to the right, the slider moves to the left but would not return to center when I release the stick. When the gyro is off and I move the rudder stick the slider will move and return to center as I release the stick. Is normal that the slider does not move back to center when the stick is release when the gyro is on? Or is there a problem with the gyro, servo or transmitter? Gyro: Futaba GY401, Servo: Futaba S3154, Transmitter: Futaba T9CHP Super, Receiver: Futaba R149DP I Appreciate any help/input on this. Thanks!
