GTX SlotCar
ME, USA Status: offline
quote:
ORIGINAL: droggy Thanks for your help on the battery. I read that you don't overcharge past 4.15v per cell and don't let it get under 3v per cell. I guess that's not true?? won't be flying for a while anyways, pretty heavy duty crash today, all out of spares for now. Have to wait 2 weeks We're always learning more about how to get longer lifespans in LiPo cells. When you read something about them, it's helpful if the article is dated. The real (absolute) danger values where damage is likely to occur are 2.65v and 4.25v. Don't drain below the 1st or charge above the 2nd. But, you are better off giving yourself a safety cushion on the lower end, just in case, so we tend to pad the 2.65v to 3v. Like Chris said, there is a difference between static and load voltage. I've always charged to 4.21 or 4.22v. I like the long flight times. Unfortunately, our cell engineers (and those of several premium batteries) have recently found that if you don't charge them that high, you will get a longer lifespan (more charge cycles) on your packs. 4.15 to 4.19 seems to be the optimum range. I've also noticed that a lot of the new auto chargers only charge to that range now. It's disturbing for me because the choice of longer flight times or longer lifespans is something I don't care to make. The useful lifespan of a LiPo cell is generally considered to be 80% of its new capacity. The mAh rating on your LiPo pack is when the pack is new. It starts dropping after the 1st use.
_____________________________
Gary SuperSkids® www.super-skids.com
