disney1
FL, USA Status: offline
Morning Rusted: I moved from fixed pitch world to the CCPM world by upgrading to a Belt CP. Did quite a lot of research before buying. I found that the Belt CP is a very good value. A lot of the parts are interchangeable with the Trex, and it is less expensive to get into initially. If you are considering hard 3-D, I would go for the carbon fiber edition, which already has, CNC aluminum head, buy a Spektrum DX6i, or a DX7, TX/RX. The RTF is a good starting point to get into the Belt CP. But the TX/RX leaves a lot to be desired. If you opt for the ARF Belt CP, I, we will be glad to help you with the parts list and even where to order the stuff. unless you can buy the Belt CP locally. I really do like my Belt CP, fun to fly and can be challanging. Also you should use at leas a 2200mah Li-po. anything less will give you CG problems. By the way, I fly a Belt CP with a Spektrum DX6i. Have A Great Day R N Sr.
