disney1
FL, USA Status: offline
Ok Guys, lets see if I did the trouble shooting correctly for a bad gyro. I went out to fly and had tested all servo movement earlier in the day. Everything worked correctly. When I connected the power the Gyro light acted normal, however when I moved the rudder stick, nothing happened with the rudder servo. I removed the gyro from the loup, and plugged the servo directly into the RX. The servo moved correctly. When I put the gyro back in the loup, no rudder servo movement. I would say that my Gyro is dead. Do you all agree??? Thanks for the help. Have A Great Day R N Sr.
< Message edited by disney1 -- 6/29/2008 7:45:13 PM >
_____________________________
R/C Helicopters are dangerous to your wealth. The only stupid question is the one you forgot to ask.
