Nitroxda
Joined: 9/17/2006 From: MEDANNorth Sumatra, INDONESIA Status: offline
quote:
ORIGINAL: heliaction tommis, if you were to go down the 2.4 road (and if you can afford it i suggest you do) i would get the DX7, although the 7th channel is not an issue with a small elec heli, i might be with a nitro if you want one in the future. DX7 and ar6200 rx can be found on ebay for $189.DX6i, DX7, Faast whatever radio you will be able to do sooo many things like setting throttle curves, pitch curves, have throttle hold function for autos, mate loads. As someone mentioned you can have model memory. With the DX7 i can have up to 20 different models set there so if i have planes, nitro heli, elec heli, anything all i have to do is select it and all the setting are there. Can you post a link where I could get such a deal? Been looking for a while..... most DX7 are above 300..... that's with servo etc etc... I only want to buy the Tx and a 6 channel Rx.
_____________________________
Belt CP w/ cnc head & tail, all carbon blades, carbon frame, Trex main shaft, landing gear, canopy. CAN''T FLY YET.. :)
