RE: ........."BELT-CP THREAD"........
Tower Hobbies
Logged in as Guest
Users viewing this topic: rcfreakazoid, JoVo
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: ........."BELT-CP THREAD"........
Page: <<   < prev  74 75 [76] 77 78 79 80 81 82 83   next >   >>
Login
RE: ...... - 7/24/2008 2:32:20 AM
phillyD
Status: offline
Hey Dis, Bill and Mike
Can't for the life of me stop the bird rotating to the right(nose) violently on throttle up. I reversed gyro in radio, on the gyro itself, gyro trim at neutral. Moved servo on boom. So what else .
Help
Cheers
< Message edited by phillyD -- 7/24/2008 5:14:23 AM >
(in reply to jimmy 1987)
       Post #: 1876
RE: ...... - 7/24/2008 3:31:26 AM
billmay
Status: offline
quote:
ORIGINAL: phillyD
Can't for the life of me stop the bird rotating to the right(nose) violently on throttle up. I reversed gyro in radio, on the gyro itself, guro trim at neutral. Moved servo on boom. So what else .
Help
Cheers
Try reversing the rudder in the TX, not the gyro.
Bill
(in reply to phillyD)
       Post #: 1877
RE: ...... - 7/24/2008 5:13:21 AM
phillyD
Status: offline
Sorry guys
This has been an ordeal. Bill I did try reversing the tx. when you do that you gotta do left stick to go right. So I put back in the stock rate gyro and all is well. Gonna do revo mixing for now. Anybody has an experience with the new ESKY HH gyro?
Cheers
< Message edited by phillyD -- 7/24/2008 5:48:46 AM >
(in reply to billmay)
       Post #: 1878
RE: ...... - 7/24/2008 8:19:04 AM
smokey5159
Status: offline
Hey Phil, Bill, disney1 - anyone!!
Hi there,
I have just bought a DX6i for my Esky Belt CP (mode 1-throttle right side) and it will not operate properly. I have taken it to the place I bought it from and they can't work it out. Do you know settings list for mode 1? - the collective moves on the wrong stick, ie left, and the aileron is on the opposite stick. It doesn't matter if you reverse the servos or swash settings, if you get one right, the other setting is wrong and vice-versa. There must be a simple guide for the mode 1 users.
Please help.
Regards Smokey
       Post #: 1879
RE: ...... - 7/24/2008 1:01:15 PM
billmay
Status: offline
quote:
ORIGINAL: smokey5159
Hi there,
Please help.
Regards Smokey
Is Mode 1 what you wanted? Are you saying that the dealer you bought it from can't get it to work right? Won't they replace it?
Don't know anything about Mode 1. Perhaps you should contact Horizon/Spektrum directly.
Bill
(in reply to smokey5159)
       Post #: 1880
RE: ...... - 7/24/2008 1:06:17 PM
billmay
Status: offline
quote:
ORIGINAL: phillyD
Sorry guys
Cheers
I thought you are using the Logictech gyro. If you're saying that your Telebee HH didn't work right and now your Logictech doesn't work either, then it sounds like you've got something wrong. Does the Logictech work Ok in standard rate mode?
Bill
[EDIT] I thought you said in an earlier post that when you replaced the Telebee with the Logictech that the Logictech was working correctly?
< Message edited by billmay -- 7/24/2008 1:21:10 PM >
       Post #: 1881
RE: ...... - 7/24/2008 2:07:35 PM
disney1
Status: offline
Evening Smokey:
Check the manual page 99 power settings, set to A-EU 328. This should fix your Mode 1 problem
R N Sr
_____________________________
R/C Helicopters are dangerous to your wealth.
The only stupid question is the one you forgot to ask.
       Post #: 1882
RE: ...... - 7/24/2008 3:06:51 PM
romihensem
Status: offline
hi guys. Romi here from singapore. just got my first heli which is a belt cp. mostly stock except for the gyro which i'm using the colco gy400, upgrade to aluminium head and using align gear. i've only like flown it twice now with basic hovering. still trying to getting used to the controls and such. its really hard even though i have like 4 yrs on plane experience on me. just a question before i get carried away here. i heard like theres a direct servo mod to the belt cp. anyone here can enlighten me on this? any difference and the pros and cons? thanx guys for any help. really appreciate it. i've tried looking up the vids on youtube but it isnt too clear. sorry for bad picture quality
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
KGH Flyers
( A member of D' Aesthetic Flyers )
(in reply to disney1)
       Post #: 1883
RE: ...... - 7/24/2008 3:14:11 PM
billmay
Status: offline
quote:
ORIGINAL: disney1
Evening Smokey:
R N Sr
I thought that was just a power output difference setting. Are you saying that has something to do with changing the TX from Mode 2 to Mode 1?
Bill
       Post #: 1884
RE: ...... - 7/24/2008 3:23:27 PM
disney1
Status: offline
Morning Bill:
That was my understanding of the power select, I may be wrong, as I have never played with the setting.
R N Sr
       Post #: 1885
RE: ...... - 7/24/2008 3:30:29 PM
billmay
Status: offline
quote:
ORIGINAL: disney1
Morning Bill:
R N Sr
Ron, I believe that Europe has a lower max. power output restriction compared to the US. I think that setting just changes the power output slightly but I may be wrong also. I was just confused by your saying that changing that setting should fix his Mode 1 problem.
Bill
       Post #: 1886
RE: ...... - 7/24/2008 4:57:24 PM
disney1
Status: offline
Bill You are probably correct. I gyess that he could actually remove the stick assemblies and swap them left for right. Would this correct the Mode 1/2 situation??
R N Sr
       Post #: 1887
RE: ...... - 7/24/2008 5:45:07 PM
phillyD
Status: offline
Hey guys
Anyone using the telebee gyro. What is the orientation. The manual seems to say label facing the tail? I had my label facing up. Just checking to see if that may have caused the gyro to not function properly.
Cheers
       Post #: 1888
