LDM
You have a few options on splitting the flaps , on my willshobby seafury , I simply started new , added top sheeting then build the bottom flap . Another option I recently did on my P40 , was to carefully remove the film from the bottom of the flap , sand it down do that its half the original size , then add a bottom flap . On my seafury I used Flite skin to make the flap along with carbon fiber rods . A few suggestions , keep everything forward of the CG , try to move your servos forward in the wing , and everything in the fuse as far forward as possible , this plane has a similar outline to the seafury and mine needed a disappointing 26oz to balance , I made the weight up with a super large flight pack and 12oz of dead weight and a saito 125 in the nose
_____________________________
LDM
