WILLHOBBY FW 190 Build
Tower Hobbies
Logged in as Guest
  Printable Version
Canopy Rails for Warbirds - ARF
Seller:  NCIS
Details:   $20.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> WILLHOBBY FW 190 Build
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
WILLHOBBY FW 190 Build - 9/30/2007 2:35:35 AM
tdifan
Status: offline
Hi guys,
I just got a Will Hobby FW-190. Was very cheap though, but you get what you pay for. it looks build nicely, I have seen pictures that are nice, but.....
Here is my (probably first) question: What kind of retract would or can you put in there. The opening for the retracts is rather small and the gerar is huge. it is 3/16th wide and about 8" long. Does anybody have experience with this, or has anybody build this 190 yet?
Any help would be greatly appreciated. I wanted to put a 26cc gas engine in there, but was advised to put a OS 91 in it for reasons of simplicity.
So, if anyone has build this, please let me, a somewhat beginner, know what to look out for and what to do.
Thanks all and have a good weekend...........
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: WILLHOBBY FW 190 Build - 9/30/2007 2:43:14 AM
LDM
Status: offline
I have the wills hobby seafury , same deal very cheap purchase but I was happy with the plane overall with the exceptions that I had to bash the wing for retracts .
My suggestions based on the seafury is widen the wells for larger wheels , use either Gear from Shindin machine /Lenny or CJet gear .
I made my own carbon fiber pushrods and did not use any of the kits hardware outside of the fuel tank .
Also you make want to use that gas engine because these planes build tail heavy
_____________________________
LDM
(in reply to tdifan)
       Post #: 2
RE: WILLHOBBY FW 190 Build - 9/30/2007 3:17:40 AM
Chad Veich
Status: online
I've got a Will's Hobbies 71" Zero that I'm reworking to be more scale. Same situation as the FW-190, fairly large airplane that looks like it was set up for .40 size retracts! I will be tearing out the existing rails and redoing the entire area to accept sturdy enough retracts to do the job. I really don't see any alternative as I can't imagine any retract that would fit the supplied rails would be anywhere near durable enough.
(in reply to LDM)
       Post #: 3
RE: WILLHOBBY FW 190 Build - 9/30/2007 12:36:42 PM
LDM
Status: offline
Agree I think thats the best advice and you will have a a higher % of less problems in the future when you have a less then perfact landing
LDM
(in reply to Chad Veich)
       Post #: 4
RE: WILLHOBBY FW 190 Build - 9/30/2007 1:16:52 PM
ticketec
Status: offline
is it just me,or is it just a repainted CMPro Fw-190?
if so there are a few threads going, including mine which i am half way throught kitbashing it a little, but LDM is right, there are a few souces for retracts like shindin, sierra etc...
thanks
dave
(in reply to LDM)
       Post #: 5
RE: WILLHOBBY FW 190 Build - 9/30/2007 2:53:02 PM
Edwin
Status: offline
I gutted my cmpro zero's retracts. Like was said 120 sized plane with 40 sized retracts. The pictures show what I did. Havent maidened yet. But they should hold up pretty good.
Edwin
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ticketec)
       Post #: 6
RE: WILLHOBBY FW 190 Build - 9/30/2007 4:56:26 PM
Sturtz
Status: offline
Edwin,,, is the wing builtup or foam ?
Kurt
AMA# 794291
Saito Club #121
(in reply to Edwin)
       Post #: 7
RE: WILLHOBBY FW 190 Build - 9/30/2007 5:35:07 PM
Edwin
Status: offline
Its built up. Not a bad job from what I saw on the inside. The covering is a frosted thick mylar material. Its painted, and didnt hold paint worth a d@mn. If they could ever get paint to stick to it, it would be nearly impervious. I discovered that rustoleum almond and ultracoat cream nearly a perfect match. Tried to upload a picture but rcu wont let me today.
Edwin
(in reply to Sturtz)
       Post #: 8
RE: WILLHOBBY FW 190 Build - 9/30/2007 11:11:20 PM
tdifan
Status: offline
Thanks for all the gret info and pics. I could not find anything on the CJ retracts. Shindin and Sierra look very nice, but they mostly refer to the KMP model, which i do not have. i did some more looking last night and found that the Robart airs are small enough to fit into the prefab cut outs. i guess i would have to bend new 3/16" wire to make it fit into what I have to work with. the wires that came with the model are bent in such a way, that if you hold it into the bays in the closeD position, the top part is touching the inside of the top of the wing, it sits very high up in the wing. I have been looking for sth to accomodate this, but have not gotten any further. Has anybody built this Willhobby 190 yet? And maybe has some pictures of it? Ticketec have you put up some pics of your built?
Andreas
(in reply to Edwin)
       Post #: 9
RE: WILLHOBBY FW 190 Build - 10/1/2007 10:38:44 AM
LDM
Status: offline
wills and CMP are totally differnat planes and manufactures . YOU can wills hobbys home website on a google search .
One thing about is that there ebay seller was one of the worse in the world "newyork grace" he is now gone and most likely hiding under another name .
The company is absolully non responsive , I mean virtually dead to nay emails at all so if you need support , parts , questions ect , good luck you are on your own .So if you buy you must buy cheap and live with the outcome , pay more then $149 total and you increase your risk of being unhappy with the work needed
LDM
       Post #: 10
RE: WILLHOBBY FW 190 Build - 10/1/2007 11:46:14 AM
ticketec
Status: offline
Hey LDM,
There are a lot of doggy dealers on ebay, and it's not CMPro who sell them on ebay. CMPro manufactures them, and that's different to who sells them. lot's of people/companies rebadge them with their own name, but they do not actually manufacture them. here in Australia, they are actually distributed by a reputable distributor and have fair product support.
when i look at the model pic's posted again, i am almost totally convinced it's one of the earlier versions of the CMPro with the built up wing, or even maybe a copy. but the canopy is exactly the same (incorrect) the tail is shaped the same, rudder etc, things that are pretty hard to get that wrong twice!!!
Not that's there is anything wrong with that. it actually helps knowing what every one else calls it so you can check out the other threads, find spare parts etc...
Dave
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ticketec -- 10/1/2007 10:14:10 PM >
(in reply to LDM)
       Post #: 11
RE: WILLHOBBY FW 190 Build - 10/2/2007 12:58:55 AM
LDM
Status: offline
hey Dave how are you ?
I have some good data on the China model scene from just talking and researching on the net .
CMP=CHINA Models was originally distributed by Giant Scale planes (Copperstown Pa ) on an exclusive basis , then when his volume dropped based on his poor servace and over shipping cost he lost the exclusive distribution .
Now they are distributed by many people from Nitro Rc and about 5 other USA distribtors .
THe biggest copy of CMP is FLYMODELS also made in China , same exact moulds and lines but cheaper quality and about $60 less money , you can see the diffrance on the Nitro website . ALSO you can see them on AK models , Alex carries both .
Wills hobbies is the parent company of willshobby , newyork grace was the factory rep for wills .The only company they (wills) was supposed to contract for was Giant SCale planes all new composite line . Its appears that line will never be introduced .
I do think(know for a fact ) that CMP/Wills & Flymodels does produce for some very reputal high end arfs , but as not to battle with so many people on that subject I rather stay out of that discussion
LDM
       Post #: 12
RE: WILLHOBBY FW 190 Build - 10/4/2007 9:56:40 AM
DanaEasterly
Status: offline
gut the old gear blocks and put stronger ones in . my spite wing slide off the table . both gear broke out,
(in reply to LDM)
       Post #: 13
RE: WILLHOBBY FW 190 Build - 10/5/2007 1:29:14 AM
LDM
Status: offline
I actually broke a dremil tool because my gear were in so good
LDM
(in reply to DanaEasterly)
       Post #: 14
RE: WILLHOBBY FW 190 Build - 10/5/2007 3:39:35 AM
John Sohm
Status: offline
Man I heard of stand off scale but that Wurger is like "stand way off in the next county" scale and squint ! But hey if you're happy with it and it flys ok, whatever blows your skirt.
J F Sohm - AMA# 192350 - IMAA# 15145
=> If at first you don't succeed, don't try skydiving <=
       Post #: 15
