RE: Aeroworks 122" Extra 260 ARF QB Assembly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: Aeroworks 122" Extra 260 ARF QB Assembly
Page: <<   < prev  1 2 [3]
Login
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 10/31/2007 2:08:44 AM
Joe Hunt
Status: offline
Couple of shots of the pipes from the exterior:
click to enlarge
click to enlarge
_____________________________
VIDEO: http://www.ruddermayhem.com/aw-96inch-260.wmv
VIDEO: http://www.ruddermayhem.com/aw-104inch_yak_04.wmv
(in reply to Joe Hunt)
       Post #: 51
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 10/31/2007 2:41:33 AM
Joe Hunt
Status: offline
Here's a couple of shots of Monkey finishing up the wiring on the Emcotec DPSI 2001 RV, etc:
click to enlarge
click to enlarge
       Post #: 52
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 10/31/2007 2:45:45 AM
Joe Hunt
Status: offline
Monkey says, "Happy to have all that done... ssshhhwwwoooo!"
click to enlarge
Monkey doing final cleanup:
click to enlarge
Monkey fired up to do the maiden this week:
click to enlarge
       Post #: 53
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 10/31/2007 11:20:15 PM
ottrod
Status: offline
Nice to see you and Monkey making the rounds again - keep up the good work!
(Make sure Monkey gets a good physical before he does the maiden!)
       Post #: 54
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 11/1/2007 1:04:05 AM
Joe Hunt
Status: offline
quote:
ORIGINAL: ottrod
lol, we're keeping him off the juice until after the maiden. haha
(in reply to ottrod)
       Post #: 55
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 11/1/2007 4:20:20 AM
smarks
Status: offline
Hope Monkey survived the earthquake!
       Post #: 56
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 11/1/2007 5:09:15 AM
Joe Hunt
Status: offline
quote:
ORIGINAL: smarks
lol, Monkey is hung over so much of the time, he doesn't know from earthquakes. lol
(in reply to smarks)
       Post #: 57
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 11/7/2007 3:30:45 AM
Joe Hunt
Status: offline
Monkey pulled the maiden!
VIDEO:
http://www.caseylauren.com/monkey5.wmv
       Post #: 58
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 2/11/2008 4:52:48 PM
ScaleKing
Status: offline
Hello Joe
Can you give me an idea on how much I should be budgeting ($$$) for completion on this plane? I am looking to purchase one in the next couple of weeks and I see here how beautifully you built yours!! Just need to know what I am up against. This model does require a Tx of at least 10 channels correct? Also it is a QB (10-12 hours) my building experience extends to H9 182 Skylane, H9 P-51, H9 Sundowner and back in 1991 a Great Planes PT-40 (When I got started!!LOL) With this resume do you think I should be lacking any skills needed to put this together? I have taken notes on all the tips and suggestions that you mentioned in this fourm and I have bookmarked all the links. I would really appreciate if we could talk before I invest so that I can do this up right.
Thx
ScaleKing
< Message edited by ScaleKing -- 2/11/2008 5:04:39 PM >
Can I do this for a living???!!
IMAC# 5530
       Post #: 59
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 2/11/2008 9:53:47 PM
bodywerks
Status: online
ARF
$1895 +$200 shipping
wing bags
$100
Spinner
$150
Prop
$115
engine
$1500
exhaust
$150-$650, depending on type
Servos
$800-$1400, depending on quality and quantity you choose
receiver(s)
about $150 each
Battery power system
$80-$250, depending on type, brand, and capacity
power system (optional, but typically recommended)
$150-$250
servo extensions
$100-150, depending on # of servos used, and quality of extensions you choose
servo arms (unless you use the Hitec servos with Karbonite arms, which come with the servos)
$80-$130
Then add about $100 for misc. hardware and switches, etc.,
__________________________________________________
TOTAL:
anywhere from $5400 to $6800
Of course, you can find used engines and servos at better prices, and you can skimp on other stuff, so the total price usually fluctuates drastically from plane to plane.
You do not need a 10 channel radio. You could easilly fly this plane on a 6 channel. However, the higher you go up in channels, the more programmable the radio tends to be. Something like the JR 9303 or Futaba 9CAP, would be plenty for intermediate to advanced setups.
As far as "can you build it?" - if you know lefty-loosy, righty-tighty, and can read, you can assemble this plane with little to no hassle. As far as doing so in 10-12 hours, no way. It can be done by two experienced builders working together with all the equipment ready to install, but a novice builder by himself, nope. Still, if you started on it on a monday, you should be able o have it flying by the following weekend, working on it 4-6 hours a day.
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to ScaleKing)
       Post #: 60
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 3/5/2008 8:36:46 AM
kochj
Status: offline
Karbonite servo arms come included?
They didn't on my 5955's?
Am I missing something?
What do these look like?
Justin
Winning isn''''t everything, it''''s all there is.
(in reply to bodywerks)
       Post #: 61
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 3/5/2008 5:53:20 PM
Mark Dennis
Status: offline
quote:
ORIGINAL: kochj
Justin
The black plastic arms are what was mentioned above. I've used those on my 42% 260 for over 300 flights and have had zero issues with them.
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to kochj)
       Post #: 62
RE: Aeroworks 122" Extra 260 ARF QB Assembly - 3/7/2008 3:57:32 PM
kochj
Status: offline
Thankyou for the input..
THanks much
Justin
Click to see fullsize image.
Click for fullsize
< Message edited by kochj -- 3/27/2008 10:52:29 PM >
(in reply to Mark Dennis)
       Post #: 63
Jump to:
