gosk8ing
Joined: 5/15/2006 From: Melbourne, AUSTRALIA Status: offline
Ive started smoothing out the plug using epoxy/microballons mixed. So far its turning out all right. Once smooth and shaped, ill cover it in a layer of .010" glass. Ill add some epoxy/microballons mix if i missed any places that needed more shaping. Ill then spray a filler primer and get it smooth as possible. Then add scale detail. If you dont use the sand method, what do you use to build up the thickness of the mold to give it stiffness? You stated polyester gelcoat might not be compatible with epoxy resins, but about normal polyester resin and epoxy resin?? Im planning to use polyester resin for the mold as i have 4 litres of it, but unless u guys highly recomend to epoxy resin, i might have to change my mind. When using polyester resin, would high temp mold release wax be ok, or should i use PVA?
