RE: Official RB Engine Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: Official RB Engine Thread! Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: Official RB Engine Thread! - 10/25/2007 1:06:27 AM
megamaxx
Status: offline
right now i am running an o.s. P3,its the only one i had in my box,but that engine really seems to like it,dont know if its the best though,havent had the engine all that long,ttoks will be back soon,sure he will be able to tell us
_____________________________
I ALWAYS FEEL LIKE,SOMEBODYS WATCHIN ME......
(in reply to snoking16)
       Post #: 101
RE: Official RB Engine Thread! - 10/25/2007 1:30:32 AM
jarett 92
Status: offline
traxxas plugs dont fit it right? i tried the ones i have from my 2.5 and none of them seemed to fit. they were too small.
Revo 2.5/RB TM523
(in reply to megamaxx)
       Post #: 102
RE: Official RB Engine Thread! - 10/25/2007 2:01:14 AM
megamaxx
Status: offline
no,no,the 523 is a turbo head,reg.plugs wont work in it
(in reply to jarett 92)
       Post #: 103
RE: Official RB Engine Thread! - 10/25/2007 7:44:48 AM
ttoks
Status: offline
i just used the RB plugs the whole time my engine was going, the #6 for break in and most normal running, used the 7 on occasion when it was cold out, run perfectly fine for me with 20% fuel, if someones experimented with other plugs please share with us, i've come into a bit of money lately and will have for a while so when i do finally get the revo going i mgiht just buy 3 or 4 different plugs and fiddle with it.
when the cop pulls you up doing 234 km/h and asks if you knew how fast you were going, say "yep i had cruise control on
       Post #: 104
RE: Official RB Engine Thread! - 10/29/2007 11:15:05 AM
megamaxx
Status: offline
i do believe my 323 had an air leak at the back plte,after replacing the start shaft,and sealing the back plate,my lsn was so richit wouldnt even pull the front wheels,
(in reply to ttoks)
       Post #: 105
RE: Official RB Engine Thread! - 11/2/2007 10:29:03 PM
snoking16
Status: offline
im having trouble with the throttle linkage. since this is the RB thread i figured i would post here too.
the carb is not oppening up all the way. i noticed that the RB carb has alot more slide movement then the stock 3.3 just wondering what you can do to get the carb open all the way. i can slide it with my finger just fine with nothing binding. im just not getting engough articulation to open the carb all the way up.
My Beer Team has a Racing Problem
       Post #: 106
RE: Official RB Engine Thread! - 11/2/2007 11:59:41 PM
madmax22
Status: offline
Hey guys n e 1 have this on their t-maxx? i was thinking about the RB .323 or the axial 28 but need a conversion kit any tips i started a post about conversion kits post here or there -thanks guys!
They call me "butthead".......
       Post #: 107
RE: Official RB Engine Thread! - 11/3/2007 12:55:14 AM
snoking16
Status: offline
u can buy a RB 523 that will fit in directly with the tmaxx. it comes with everything you need just like the revo.
(in reply to madmax22)
       Post #: 108
RE: Official RB Engine Thread! - 11/3/2007 1:23:00 AM
ttoks
Status: offline
for the varb problem, the best fix i found was getting a new throttle servo, after that it opened past the carb body, but still not all the way, the stock linkage is the problem, it doesnt allow enough movement for the RB carb.
       Post #: 109
RE: Official RB Engine Thread! - 11/3/2007 1:26:47 AM
megamaxx
Status: offline
quote:
ORIGINAL: snoking16
i had the same prob.with my 523,all i did was move the ball linkage so its above the spur tension nut,that allowed me to adjust the carb.angle to get full movement
       Post #: 110
RE: Official RB Engine Thread! - 11/3/2007 1:40:41 AM
snoking16
Status: offline
i can move the carb around fine...i noticed that the metal linkage bar bends pretty good when i give it WOT.
       Post #: 111
RE: Official RB Engine Thread! - 11/3/2007 1:41:19 AM
minipro
Status: offline
Will the RB 523 fit with a big block conversion such as the Qoncepts? Or is the RB mount the only one that is compatible?
(in reply to RenegadeRevo)
       Post #: 112
RE: Official RB Engine Thread! - 11/3/2007 5:05:12 AM
ttoks
Status: offline
no, the crank case on the RB is a good half an inch short then a true big block, so with w big block kit the clutch bell wont meet the spur gear.
(in reply to minipro)
       Post #: 113
RE: Official RB Engine Thread! - 11/3/2007 11:03:46 AM
megamaxx
Status: offline
quote:
ORIGINAL: snoking16
sometimes i can be such a putz!!!!didnt even pay attention to the fact of you needing revo advice,sorry about the useless t-maxx advice!!!
       Post #: 114
RE: Official RB Engine Thread! - 11/3/2007 9:30:45 PM
snoking16
Status: offline
^^^yeah dude...i had no idea what you were talking about.haha
       Post #: 115
RE: Official RB Engine Thread! - 11/4/2007 4:11:56 AM
madmax22
Status: offline
Hey sorry but i cant find the RB's anywhere????? will the 323 fit directly in the maxx???i hear the only diff is the 323 is a 5 port the 534 is a 7 port?????? how much does the 323 and the 534 cost???(websites are greatly accepted)-thanks
       Post #: 116
RE: Official RB Engine Thread! - 11/4/2007 4:25:54 AM
ttoks
Status: offline
the 323 is a 7 port (5 intake plus 2 bypass plus 1 exhaust) and the 523 is a 9 port (7 intake plus 2 bypass plus 3 exhaust), there are a lot of differences though, the 523 uses a 14.2mm crank, the 323 uses a standard 13mm, the 523 also has larger bearings, a new head button, and the crank case is ported differently because the sleeve is A 9 port rather then 7.
neither will drop directly into the max or revo, the crankcase is much wider then the stock engines, you need the RB engine mounts (which are supplied with the engine along with an exhaust system)
here is a link to the 523 kit for the maxx, that is the best deal i could ind for the max kit at $258 USD (the revo kit costs the same).
the only place i could find that sells the 323 for either the max or revo in an Australian online site, the 323 has been removed from RB's website so it may have been discontinued, i don't know for sure though.
