squeeguk
Joined: 3/21/2004 From: Camberley, UNITED KINGDOM Status: offline
quote:
ORIGINAL: beer=food Well yea ! Thats like comparing a 4 cylinder to a 6 ! LOL ! Sqeekguy, why do you have such long fuel lines, you add resistance, needing more fuel backpressure to keep fuel pressure up to carby, the G-forces in sharp corners would be throwing that fuel line tube around, because of its mass with fuel in it, giving you an uneven fuel pressure at the carby, minor as that may seem, you have a niggly problem, its worth shortening them lines, it cannot hurt at all.There should be no pressure difference ,no matter which way you turn, the tank being where it is , is no issue, the tank is not offset at a higher or lower level to the engine and the outlet does not face left or right, the fuel is drawn straight 'up' and out, the effects should be unseeable.Shorten your tube, dont run it flat at the front of your chassis, having flat side to side lengths of fuel line makes the fuel in the line vulnerable to gravity forces in corners, think virtical, get your tube to do a virtical loop through the designed clips and straight into carby, halve the length of the line as well, place the fuel filter on the lower clip, but think virtical not horizontal with fuel line, the fuel in it has a small mass and is effected by G-forces in corners.The colder it is, the 'thicker' your fuel will be, definately shorten your fuel lines. Cheers mate, but I had the lines short, like you mentioned and had the same issue, I tried this only because someone mentioned something about the fuel running into the pressure line and cauing uneven pulses. I will shorten them again as I don't like so much fuel line around the car and it's made absoutely no difference at all. I cannot understand how some people say that havng a different tank changes things so dramatically to get rid of the problem. It is really noticeable the rich and lean turning. What setup do you have on yours? Could it maybe be that I am running it too rich and thus it is so noticeable? I am seriously considering doing the single steering, rx box and MBX-5T conversion just to get rid of it, just crazy that I am having to spend all that money just cos I bought a better engine????
_____________________________
Traxxas Revo 3.3 with RB TM523 - Spektrum DX3.0 Hobao Hyper ST Pro - Spektrum DX3.0
