RE: 2 for one - Carden 40% Extra 300 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 2 for one - Carden 40% Extra 300 Build
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: 2 for one - Carden 40% Extra 300 Build - 12/22/2007 2:27:18 AM
kregan
Status: offline
I did have a problem in a few places with the grain lifting on the balsa but
it did it with 2 different kinds of tape.
Yea, the 3D school sounds "interesting" !
Tonight I finished fitting the rudder to the second plane and then started to
work on the canopy hatch. First thing I needed was to make the hold down
tabs, 6 for each plane.
I made some 1/8" ply tabs and 1/8" ply washers as spacers for the the blind
nuts. I sanded them to shape, but left them a little long until they are glued to
the hatch rails.
Pictured is the cutter used to make the shouldered holes for the socket cap
screws in the side of the fuse.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Kelly
Flying at FSA? We got your B.A.C.C. !!!
(in reply to OnTheEdge)
       Post #: 226
RE: 2 for one - Carden 40% Extra 300 Build - 12/22/2007 4:34:52 PM
as722
Status: offline
quote:
ORIGINAL: mrbigg
Obviously some don't know how long it takes to build a plane, let alone two at the same time. Not to mention doing a build thread, which is work in itself. Keep up the good work. I check this thread everday for new stuff.
First of all I was kidding with Kregan, which he knows. And second I happen to know a few things about the carden 300 since I built the prototype including a full build thread from start to finish.
Albert
Carden Aircraft
(in reply to mrbigg)
       Post #: 227
RE: 2 for one - Carden 40% Extra 300 Build - 12/22/2007 7:56:41 PM
mrbigg
Status: offline
quote:
ORIGINAL: as722
quote:
ORIGINAL: mrbigg
Albert
Sorry, I thought you were really ragging on him. My apologies.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
(in reply to as722)
       Post #: 228
RE: 2 for one - Carden 40% Extra 300 Build - 12/22/2007 8:45:53 PM
kregan
Status: offline
Time for a group hug!
Kelly
       Post #: 229
RE: 2 for one - Carden 40% Extra 300 Build - 12/23/2007 12:35:15 AM
kregan
Status: offline
Well...... today I built the frame for the first canopy.
First I had to make the rear frame piece. then it needs to be sanded
smaller all around so the canopy will be flush with the finished turtle deck.
The same thing needs to be done to the hatch rails. I used the mill to make
that cut. Once that was done I glueg the rails to the canopy mounting tabs.
I will be doing a semi open canopy floor so I built the cross bracing to mirror
the bracing under it.
Made sheet metal templates and cut the extra foam from the front deck and
glued the deck in place along with the front 1/4" balsa piece.
The frame is still fragile but it will gain strenght as the floor and other parts
are installed.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by kregan -- 12/23/2007 1:41:28 AM >
Kelly
(in reply to kregan)
       Post #: 230
RE: 2 for one - Carden 40% Extra 300 Build - 12/23/2007 1:16:18 AM
kregan
Status: offline
more...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by bubbagates -- 12/23/2007 1:38:08 AM >
Kelly
       Post #: 231
RE: 2 for one - Carden 40% Extra 300 Build - 12/23/2007 2:10:35 PM
1fireball
Status: offline
Nice job keep the build going!
       Post #: 232
RE: 2 for one - Carden 40% Extra 300 Build - 12/25/2007 12:29:29 AM
as722
Status: offline
quote:
ORIGINAL: kregan
I don't know about a hug but definetely a cold drink. The 300 is looking awesome, can't wait to see it in person.
Happy holidays to all.
Albert
Carden Aircraft
       Post #: 233
RE: 2 for one - Carden 40% Extra 300 Build - 12/25/2007 12:30:41 AM
as722
Status: offline
quote:
ORIGINAL: mrbigg
quote:
ORIGINAL: as722
quote:
ORIGINAL: mrbigg
Albert
No problem, happy holidays.
Albert
Carden Aircraft
       Post #: 234
RE: 2 for one - Carden 40% Extra 300 Build - 12/29/2007 12:53:23 AM
kregan
Status: offline
Sorry for the lack of movement on the planes....
I was planning to work on them the day after Xmas but I woke up
the next morning with a bad sore throat and feeling generally crappy.
Went the the Doctors today for a look and a culture, it won't be back
until 2008!!! He thinks it viral, so no antibiotics.
Our siding and roofing company sent use some 12 year old Johnnie Walker
Black Label Scotch along with 2 glasses for Christmas... Maybe that will make
it hurt less!!!
Kelly
(in reply to as722)
       Post #: 235
RE: 2 for one - Carden 40% Extra 300 Build - 12/29/2007 11:15:28 PM
kkling77
Status: offline
quote:
ORIGINAL: kregan
it hurt less!!!
If it doesn't work give me a call and I will come over and try to help you figure out what is wrong with it!!!!
       Post #: 236
RE: 2 for one - Carden 40% Extra 300 Build - 1/2/2008 7:41:06 PM
walkerk12
Status: offline
Do you plan to glass the hatches?
If it don't fly it aint worth play'n with!!
(in reply to kkling77)
       Post #: 237
RE: 2 for one - Carden 40% Extra 300 Build - 1/3/2008 10:20:06 PM
ibow24
Status: offline
Kelly,
I haven't checked out your build thread for awhile. Finally got a chacne today to page through it. Excellent work, they look great.
The impressive thing to me is you're building 2 at once, the craftsmanship looks top notch and you're making great progress.
Good job. Keep up the good work. I'm looking forward to seeing the finsihed twins.
Steve
(in reply to walkerk12)
