RE: 2 for one - Carden 40% Extra 300 Build
Tower Hobbies
Logged in as Guest
  Printable Version
Carden 35% Extra 260 - RTF
Seller:  jmiracle
Details:   $2,950.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 2 for one - Carden 40% Extra 300 Build
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: 2 for one - Carden 40% Extra 300 Build - 1/10/2008 2:05:22 AM
DrDeath
Status: offline
Do like I did. I placed the rubber matting down. It comes in 2x2 interlocking sections. I really need to get back in my shop soon. The sad part is that you will have finished two Cardens and I still have my Spacewalker in bones
_____________________________
My Website http://mysite.verizon.net/ldharris84/
Club Site http://www.freestateaeromodelers.org/
(in reply to kregan)
       Post #: 251
RE: 2 for one - Carden 40% Extra 300 Build - 1/11/2008 3:45:49 AM
kregan
Status: offline
Second plane is up to speed....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
Flying at FSA? We got your B.A.C.C. !!!
(in reply to DrDeath)
       Post #: 252
RE: 2 for one - Carden 40% Extra 300 Build - 1/11/2008 6:13:47 PM
flyme2dmoon
Status: offline
Looking great, Kelly!
       Post #: 253
RE: 2 for one - Carden 40% Extra 300 Build - 1/13/2008 2:21:48 AM
kregan
Status: offline
Thanks Neil!
I had time to work on the engine install today. I used the left over 1"x1" hard point
mounts from the kit and milled them to 2.5 degree angle. I mounted the engine and
tack glued the ply blocks in place.
I have temporary aluminum spacers installed for the fitting. Once I have everything
checked out I plan on turning permanent aluminum spacers.
I will be using 5mm mounting bolts with locking nuts for the engine mount.
I have the cans swapped, left for right in the picture... Just an idea I had for a second.
quote:
ORIGINAL: flyme2dmoon
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
(in reply to flyme2dmoon)
       Post #: 254
RE: 2 for one - Carden 40% Extra 300 Build - 1/13/2008 4:06:18 AM
kregan
Status: offline
Question....
I have never set up cans before and I want to know if this looks OK
(red arrow in the last picture) or do you think I need to add extensions
to the header so it pushes the cans deeper into the pipe tunnel?
This looks great to me... No spacer blocks on the header, and no pipe
extensions!
To me it fits like a glove and I'm not talking OJ here!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
       Post #: 255
RE: 2 for one - Carden 40% Extra 300 Build - 1/15/2008 3:05:43 AM
kregan
Status: offline
OK so I am going with that setup....
Here is what I cam up with for a rear mount. It is pretty tight up
front so I am thinking of supporting the front of the cans right behind
the coupler on the neck.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
       Post #: 256
RE: 2 for one - Carden 40% Extra 300 Build - 1/15/2008 3:27:02 AM
DMichael
Status: offline
Cans look good, Kelly.
Team ZDZ
www.rcshowcase.com
       Post #: 257
RE: 2 for one - Carden 40% Extra 300 Build - 1/17/2008 2:44:21 AM
kregan
Status: offline
After some advice about the rear can mount I made new
donuts for the can mount. These have more surface area
so the plywood won't dig into the silicone mounts.
I also framed up and built the pipe floor and front bulkhead.
The pipe floor is in 2 sections. one is removable in case I need
access to the pipe mount.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
(in reply to DMichael)
       Post #: 258
RE: 2 for one - Carden 40% Extra 300 Build - 1/19/2008 1:15:02 AM
kregan
Status: offline
This is the second night messing with the split cowl...
I glued in the 5 ply blocks for the blind nuts on one side of the cowl.
I also have scrap balsa taped around the fuse to help line up the cowl
for fitting.
I modified the lower attachment points of the cowl. It is hard to explain
but basically the lower half is screwed into blind nuts that are located inside
the fuse. Access to the lower bolts is from the bottom cutouts for the pipes.
I will be adding alignment pins each side of the lower cowl mounts.
In the last 2 pictures it looks like I will have to make a new upper cowl
support, part C1. The one supplied with the kit has a different radius and
is about 1/4 inch small on both sides.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
       Post #: 259
RE: 2 for one - Carden 40% Extra 300 Build - 1/19/2008 2:02:24 AM
as722
Status: offline
Kelly,
I had the same issues with my top cowl ring. All I did was to cut the the corners flat and added a piece of balsa and cut the ring to the correct shape. I traced the front of the hatch and then cut the ring using the inside of the line to allow for the thicknes of the cowl.
Albert
Click for fullsize
Carden Aircraft
       Post #: 260
RE: 2 for one - Carden 40% Extra 300 Build - 1/20/2008 2:06:15 AM
kregan
Status: offline
