RE: 2 for one - Carden 40% Extra 300 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 2 for one - Carden 40% Extra 300 Build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: 2 for one - Carden 40% Extra 300 Build - 10/7/2007 5:48:50 PM
weathervane
Status: offline
Kelly, It looks like you are off to a great start. You do some nice work.
-Andrew
_____________________________
R.I.P. Snowman (Jerry Reed 1937-2008)
www.freestateaeromodelers.org
(in reply to kregan)
       Post #: 26
RE: 2 for one - Carden 40% Extra 300 Build - 10/8/2007 12:22:42 AM
kregan
Status: offline
Thank you Andrew,
The first pair of stabs look great! I have them trimmed up and ready
for the leading edge and trailing edge stock to be glued on.
The second pair of stabs just came out from under the weight and need
trimming and prep but look great also.
I cut and taped together the pieces for both rudders. I glue one rudder
and just placed it under the weight for the night.
I think that is it for tonight.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
Flying at FSA? We got your B.A.C.C. !!!
(in reply to weathervane)
       Post #: 27
RE: 2 for one - Carden 40% Extra 300 Build - 10/8/2007 2:48:17 PM
ibow24
Status: offline
Nice shop...I would be building a full scale if I had that shop
Steve
       Post #: 28
RE: 2 for one - Carden 40% Extra 300 Build - 10/8/2007 4:12:12 PM
airborneSGT
Status: offline
Thats what I was thinking I think my next house I will build a barn or a prefab steel structure for the "shop".
(in reply to ibow24)
       Post #: 29
RE: 2 for one - Carden 40% Extra 300 Build - 10/9/2007 9:15:30 PM
kregan
Status: offline
Slow progress, someone forced me to play golf yesterday and
now the kids are getting sick (back to school is so much fun!).
Rudder/fin, One is sheeted and ready for leading and trailing edge,
the second one is glued and under weight.
Both pairs of stabs/elevators are sheeted.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
       Post #: 30
RE: 2 for one - Carden 40% Extra 300 Build - 10/9/2007 10:40:33 PM
kkling77
Status: offline
It doesn't look like that golf game slowed you down much!!
       Post #: 31
RE: 2 for one - Carden 40% Extra 300 Build - 10/10/2007 1:19:39 AM
DrDeath
Status: offline
Sorry I missed the golf game. I really wanted to go!!!! Also, your mom and pop look like they were having a good time up at the lodge on Sunday.
DD
My Website http://mysite.verizon.net/ldharris84/
Club Site http://www.freestateaeromodelers.org/
(in reply to kkling77)
       Post #: 32
RE: 2 for one - Carden 40% Extra 300 Build - 10/11/2007 12:15:10 PM
JKEpps
Status: offline
Hey Kelly, what glues (types, i.e. CA, epoxy, poly ...) are you using for the different parts and sheeting, and why? With your construction and building experience, I figure you probably have a great idea of what glue works where, and more importantly, which ones don't. I tend to use CA for the bulk of my construction, and poly and epoxy where needed. I've never sheeted foam wings before, but I hear a lot of guys are have great success using a very thin layer of poly and using water to "kick" it.
-Jorden
(in reply to DrDeath)
       Post #: 33
RE: 2 for one - Carden 40% Extra 300 Build - 10/11/2007 9:51:22 PM
DMichael
Status: offline
Kelly,
I found that template for cutting the hole in the firewall for the ZDZ160.
I've been in bed sick.... will let you know if I'm feeling better tomorrow and, if so, I'll drop it off at your house.
Dave
Team ZDZ
www.rcshowcase.com
(in reply to JKEpps)
       Post #: 34
RE: 2 for one - Carden 40% Extra 300 Build - 10/12/2007 2:35:09 AM
kregan
Status: offline
Jorden,
Sheeting to foam:
It was a toss up between Urethane and laminating epoxy for this application.
I decided to go with urethane for ease of use (no mixing) and availability.
Wood frame:
Yellow carpenters glue... No fumes, fun to peel off your fingers, cost,
easy to sand. CA would be fine for this if you like.
Firewall, motor box etc. :
I will use 30 minute+ epoxy... Strong and I can add
milled fiberglass for strenght.
Hope that helps
quote:
ORIGINAL: JKEpps
-Jorden
Kelly
       Post #: 35
RE: 2 for one - Carden 40% Extra 300 Build - 10/12/2007 2:48:01 AM
kregan
Status: offline
That is OK Dave, no hurry. I have had a couple of slow
days (ask Kurt) and haven't made much progress.
Here is one of the hatch covers sheeted. I decided to add
the 7/8" balsa strips per plan, but I glued them on first so
the sheeting would cover over the edge and eliminate a
visible joint.
I kept the 7/8" strip one the bottom so I could use carpenters
glue to join it to the fuse instead of urethane. That might
be easier to work with and make a smoother joint.
I will cut away the extra foam later in the build.
quote:
ORIGINAL: DMichael
Kelly,
Dave
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
(in reply to DMichael)
       Post #: 36
RE: 2 for one - Carden 40% Extra 300 Build - 10/13/2007 2:53:31 AM
capflyr
Status: offline
Man I dont know what to say awsome build great pics keep it up. Manny I will buy one if you due
we can build em together.
       Post #: 37
RE: 2 for one - Carden 40% Extra 300 Build - 10/14/2007 2:37:29 AM
weathervane
Status: offline
WOW, Kelly you have done more in two weeks than I did in nine mounths. Looks great. Keep it up.
-Andrew
(in reply to capflyr)
       Post #: 38
RE: 2 for one - Carden 40% Extra 300 Build - 10/14/2007 4:07:26 PM
