RE: 2 for one - Carden 40% Extra 300 Build
Tower Hobbies
Logged in as Guest
  Printable Version
Great Planes Giant Aeromaster ARF - ARF
Seller:  JSZ
Details:   $600.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 2 for one - Carden 40% Extra 300 Build
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: 2 for one - Carden 40% Extra 300 Build - 10/18/2007 11:46:27 AM
ibow24
Status: offline
With a 1.25 servo arm I set my hard point up at 1" offset from the centerline of the servo.
This seems to gives a good balance from neutral to endpoints.
Steve
(in reply to kregan)
       Post #: 51
RE: 2 for one - Carden 40% Extra 300 Build - 10/18/2007 7:19:54 PM
kkling77
Status: offline
I concur. An 18 hole meeting is definitely in order to discuss such important issues. Hell, while we're at it we might as well make it a 19 hole event and get some real good ideas on the table!!
quote:
ORIGINAL: kregan
Anyway, I will sleep on it.... Maybe Kurt and I need to
conduct a 18 hole meeting and talk this out!
       Post #: 52
RE: 2 for one - Carden 40% Extra 300 Build - 10/19/2007 2:18:56 AM
capflyr
Status: offline
I 2nd that I set all my stuff up that way and it works great you get A stronger end point due to mech advantage
(in reply to ibow24)
       Post #: 53
RE: 2 for one - Carden 40% Extra 300 Build - 10/20/2007 8:24:01 PM
kregan
Status: offline
I finally had time to do some wing prep.
First I made a template for the servo layout. I like working with
templates to reduce the chance of error.
I needed to cut the servo wire holes so I broke out my Weller
soldering gun and made cutter out of 14 ga. copper wire. I had
seen pictures of this done and just copied it.
Laid out the servo wire channel (straight line) checked the plan
to make sure servo wire would exit in a good spot and burned
the holes. I used an aluminum angle as a straight edge and
a depth guide.
Next I routed out the servo locations, glued in the servo mounts
and put everything up to dry.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Kelly
       Post #: 54
RE: 2 for one - Carden 40% Extra 300 Build - 10/20/2007 8:31:40 PM
mrbigg
Status: offline
quote:
ORIGINAL: kregan
a depth guide.
Keep up the good work! Looks really nice so far. Does Carden put the holes in the foam for the wing tube or do you have to do that?
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
       Post #: 55
RE: 2 for one - Carden 40% Extra 300 Build - 10/21/2007 2:40:25 AM
kregan
Status: offline
Mrbigg...
The Carden wings do come with the wing tube
hole already cut.
With the wing tube sockets glue in place that completes
the wing prep and I am ready to sheet the first main wing.
I put together the sheeting for one wing tonight.
The wings are approx. 53" long. The wing sheeting is
48" long. The instructions have you glue all the extra 5"
sheeting in a straight line out near the wing tips. I decided
to deviate from the plan and cut 1.5" off every other strip
of sheeting to create a staggered joint. This would hide
any straight glue line that could possibly show up under
the covering.
Wayne and Steve...
I will take your advise and offset the hard points a little.
They will be added later and I can adjust them at that time.
I hear from Dennis that Wayne's plane, built by Walt was at the
Toledo show... I told Dennis that my goal was to try and achieve
that level of quality! I hope I can come close! Kurt is even getting
a balsa servo wire tube (maybe) !
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
(in reply to mrbigg)
       Post #: 56
RE: 2 for one - Carden 40% Extra 300 Build - 10/21/2007 12:36:02 PM
weathervane
Status: offline
Looks great Kelly.
Good family values last a lifetime. Stop the violence!!!
www.freestateaeromodelers.org
       Post #: 57
RE: 2 for one - Carden 40% Extra 300 Build - 10/21/2007 5:02:35 PM
kregan
Status: offline
After cutting a piece of plywood to fit the main wings
I glued up the sheeting and got the first wing under
weight.
I come up with 460 pounds with the tile and brick.
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
       Post #: 58
RE: 2 for one - Carden 40% Extra 300 Build - 10/21/2007 10:20:15 PM
capflyr
Status: offline
That is one strong table keep it up I check every night to see your progress looks great.
       Post #: 59
RE: 2 for one - Carden 40% Extra 300 Build - 10/22/2007 3:00:30 AM
DMichael
Status: offline
Hey Kelly- looking great- sorry I didn't get over there. I saw that you had the servo bays marked out so I figured you were good. You are doing a great job.
Dave
Team ZDZ
www.rcshowcase.com
(in reply to capflyr)
       Post #: 60
RE: 2 for one - Carden 40% Extra 300 Build - 10/22/2007 3:19:51 AM
kregan
Status: offline
Sorry I could not make it out to fly today. Rachel had a great
idea to take the kids to Centenial Park for a "trick or treat trail",
to bad 15,000 other moms, with 2.5 kids each, had the same
idea!
Back to progress.....
I have one wing sheeted and trimmed ready for LE and TE.
The other wing is under weight. I also pulled out the next
pair of wings for a picture in the buff.
Look at the wasted foam in the box, any ideas for that besides
dumpster fill?
BTW,
Any problem using urathane glue for the LE and TE instead of
aliphatic resin (wood glue) that the instructions call for? My
though is the urethane would force itself into the edge of the
foam and balsa filling any small voids.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
(in reply to DMichael)
       Post #: 61
RE: 2 for one - Carden 40% Extra 300 Build - 10/22/2007 12:11:31 PM
DMichael
Status: offline
If you use the urethane glue on the leading and trailing edges just be sure to have them secured- the expansion of the glue might cause some problems.
Team ZDZ
www.rcshowcase.com
       Post #: 62
RE: 2 for one - Carden 40% Extra 300 Build - 10/22/2007 2:20:43 PM
BBW Walt
Status: offline
BTW,
It will work, use a lot of tape to pull it down, every 2 inches or so. I use Titebond II. Its less mess and works just as well maybe better in my opinion. Tips and end caps I use 5 minute epoxy. I use an acid brush with the bristles cut back to 1/4 inch. The epoxy can be brushed real thin just enough to stick it on. In a couple minutes you can shape the piece and the epoxy will sand clean. Done correctly its very light, very little glue, Walt
