RE: H9 ultimate questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> TEAM RCU - Mike McConville >> RE: H9 ultimate questions
Page: <<   < prev  1 [2]
Login
RE: H9 ultimate questions - 1/8/2008 4:24:42 PM
pfact
Status: offline
some more details for you - I glued 3/16" basswood strips to the middle and outer edges of the ply. Each of the strips has a 1/16" deep notch dadoed into its underside to allow placement of a velcro strap or zip tie.
Glitches? Dropping of the right wing occurred in 3 planes at 2 fields and we did not experience the problem when we used a 9C. This allowed us to narrow the problem down to our 14Mz transmitter. We sent it in for repair, they turned it around quickly unfortunately, they did not provide us with any specific indication of what was done. Some clues from the Futaba service center web site made us think they replaced a pot and gimbal for the right stick.
Unfortunately, we encountered the problem again this weekend with our Boomerang. This is very unsettling as we have a Bobcat, Rookie, 3.3M Yak, 2.6M Yak, and a QQ Python that need to be maidened this Spring - not sure we should take the risk, rather it may be time to switch to JR. The thought of replacing receivers on 30+ planes is too much to stomach.
Phil
(in reply to Lormuhl)
       Post #: 26
RE: H9 ultimate questions - 1/9/2008 12:47:02 AM
mradcliff
Status: offline
Thanks guys for the tank pictures. It really helps.
Mark
       Post #: 27
RE: H9 ultimate questions - 1/9/2008 2:13:39 AM
Lormuhl
Status: offline
Ouch sorry to hear about the radio/glitch problems. It would be hard to swallow replacing receives in 30+ planes. Were you using the 14mz in the Boomerang or the 9C? I have only used JR and since I have gone to 2.4 I have not had one glitch in any of my planes. I will have to ask you for your advise when I'm ready for my first turbine.
(in reply to mradcliff)
       Post #: 28
RE: H9 ultimate questions - 6/23/2008 2:48:52 AM
mradcliff
Status: offline
I have a Hanger 9 Ultimate with about a dozen flights on it and I love it but Im concerned about the top wings are seperating at the center carbon fiber rib. I start out tight and after a flight there is approx a 3/16 to 1/4" gap. If it moves much more I'm concerned it could seperate past the anti rotation pins. Also I'm having trouble with the 4/40 screw to keep the wing from sliding left to right. It's stripped. The alum tube is so thin you can barely get a thread in it to hold the screw. Does anyone have a better set up?
       Post #: 29
RE: H9 ultimate questions - 6/23/2008 10:47:37 PM
MMcConville
Status: offline
Easy solution here is to epoxy a hard block such as maple inside the tube, then tap it 6-32, and go to 6-32 bolts to retain the top wing. That should make everything solid.
_____________________________
Mike McConville
Horizon Hobby
       Post #: 30
RE: H9 ultimate questions - 6/25/2008 2:43:04 AM
mradcliff
Status: offline
OK Mike I was thinking along the same idea. I'll give it a try.
Mark
(in reply to MMcConville)
       Post #: 31
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
