somegeek
WA, USA Status: offline
quote:
ORIGINAL: Krener SG, what kind of control rods, links, horns etc are you going to use on this bird?? Are you going to do a dual aileron servo mod?? Ailerons on upper wing also?? Cmon, gimme info........gimme gimme gimme!!!! Gonna use Dubro 1/2A horns when I add the upper ailerons. 2-56 rod for all control rods cept the throttle which will be a cable. Thinking the 2-56 should do fine on this small of a plane for the tail feathers. I ran 2-56 control rods about 6" long on a stryker that had larger control surfaces and it did fine when zipping along at ~75mph and pulling out of dives. somegeek
_____________________________
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
