rc4flying
PA, USA Status: offline
quote:
ORIGINAL: off2fly Joe,They told me 228.00 Ea.for pipes,48.00 Ea. for Headers 25.00 for couplings and stuff.Did you check on engine thrust angle? I'll bet those 170's will kick butt!I don't think this plane will need it being under 42# I had a extra w/cans weighed 44# the 150 would hover less than half throttle,It hauled that plane!Thanks,Vann Vann, That is not as bad as I was expecting, but still a chunk of $$$$$. I want to quite my planes down, but the money spent on the pipes could go for the 170. And decide from there. I will probably go until after Xmas to decide and just get the rest of the plane setup. As far as the engine thrust, it is already setup with right thrust in the motor box. I put a squre against the side of the fuse and you can see the right offset. Plus the standoff are all ready made up and the same size and the firewall is marked out for a DA 150 hole pattern. Should be pretty easy no matter which way you go for pipes and a 150. Hopefully the 170 will have the same hole pattern.
