RE: 120" Yak questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> RE: 120" Yak questions
Page: <<   < prev  2 3 4 5 [6] 7 8 9 10 11   next >   >>
Login
RE: 120" Yak questions - 11/23/2007 6:21:18 AM
Rezagh
Status: offline
Vann,
My friend is building mine. I have not even seen the plane personally as it was shipped to him but I always use supplied hardware and that's what he's used.
I will ask him to see if mine is same as yours and I will let you know.
Thank you,
Reza
_____________________________
Quique's Aircraft Company
(in reply to off2fly)
       Post #: 126
RE: 120" Yak questions - 11/23/2007 1:25:03 PM
off2fly
Status: offline
Thank you much!
(in reply to Rezagh)
       Post #: 127
RE: 120" Yak questions - 11/23/2007 5:58:43 PM
rc4flying
Status: offline
Vann,
No, I used the new "Knuckle" style headers that after you get them where you want, carfully take them off and you solder them with a type of silver solder I got from DA for the job. Very easy to do.
rc4flying
Joe
       Post #: 128
RE: 120" Yak questions - 11/23/2007 11:22:38 PM
off2fly
Status: offline
Well i guess i got the wrong ones!Bummer.
(in reply to rc4flying)
       Post #: 129
RE: 120" Yak questions - 11/24/2007 12:40:22 AM
rc4flying
Status: offline
What did you get ? One that only have a 50mm drop ?
That is what I got from DA on the first try, but luckily I had a set of 70mm drop headers to keep things going.
But now, I just opened up my new battery order from Fromeco, and they are not what I ordered. I even rechecked my confirmation email from then, And I got the wrong ones. So, now I will have to call them on Mon. Bummer..........
rc4flying
Joe
       Post #: 130
RE: 120" Yak questions - 11/24/2007 2:19:48 PM
off2fly
Status: offline
No, I got 70mm drop headers,they're just not flexible .I'm going to try them and see what they look like.I hear they're having a hard time filling orders at fromeco,they are selling like hotcakes,I believe them to be the best batteries and regs available,and they are great guys,call kurt he'll make it right fast!
       Post #: 131
RE: 120" Yak questions - 11/24/2007 4:20:00 PM
rc4flying
Status: offline
Vann,
Here is my header setup. They were adjustable before i solder them together. They have what looks like slip knuckles. Other then it being my first attempt at doing this kind of silver soldering, which as you can see is not the neatest, they seem to be very strong. I have a length of 9 3/4" and a 1/4" gap between header and pipe.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
rc4flying
Joe
       Post #: 132
RE: 120" Yak questions - 11/24/2007 4:51:07 PM
quist
Status: offline
You might need to put more separation on the header/pipe. Most are using a minimum of 1/2". These pipe grow when they get hot. With this soft mount it may never be a problem, but with the factory greve mount (hard mount) we had to put 3/4" separation. The pipe would grow so much that is mushroomed the end when it pushed against the header. Of course we had some lock out issues with the radio also.
       Post #: 133
RE: 120" Yak questions - 11/24/2007 6:50:52 PM
rc4flying
Status: offline
quote:
ORIGINAL: quist
Thanks, I will have to keep that in mind. I am maybe hoping that with this type of slip in mounting, that it would not be a problems. I will keep an eye on this, or maybe the next time I have the cowling off, I will trim the headers,
With say that 1/2" separation between the pipe and header, how does the teflon coupler hold up ?
rc4flying
Joe
(in reply to quist)
       Post #: 134
RE: 120" Yak questions - 11/24/2007 7:18:17 PM
quist
Status: offline
I never had a Teflon failure.
       Post #: 135
RE: 120" Yak questions - 11/24/2007 7:32:21 PM
storklappe
Status: offline
Quist,
Were your "lock out" issues caused by the metal-to-metal contact?
(in reply to quist)
       Post #: 136
RE: 120" Yak questions - 11/24/2007 9:29:32 PM
rc4flying
Status: offline
quote:
ORIGINAL: quist
That is good to know. I think I will leave it for not and keep an eye out on it if I get a chance to fly it here soon. If the weather really sets in for the cold winter, I will get in there and put a bigger gap.
Do you guy use anything else to hold the teflon coupler or are the clamps enough with a smooth end on the headers ????
rc4flying
Joe
(in reply to quist)
       Post #: 137
RE: 120" Yak questions - 11/25/2007 2:21:53 AM
quist
Status: offline
quote:
ORIGINAL: storklappe
Quist,
Yes, this same problem happened to many people.
(in reply to storklappe)
       Post #: 138
RE: 120" Yak questions - 11/25/2007 3:35:33 AM
off2fly
Status: offline
Yea i silver soldered some pipes similar to them for a friend of mine.On the 3w pipes I heated the couplings up w/torch before I slid them on and clamped(cleaned w/alcohol first) never had a leak!DA said just let them run at idle for 3min. then let them cool.Man we had a beautiful day flying today,you did'nt try that bird out yet?
       Post #: 139
RE: 120" Yak questions - 11/25/2007 3:36:43 AM
off2fly
Status: offline
whats lock out?
(in reply to quist)
       Post #: 140
RE: 120" Yak questions - 11/25/2007 4:31:53 AM
quist
Status: offline
PCM receiver holding last know position because of interference.
